D2 no spark but..........
Showing 1 to 10 of 10 results
toolhawk
Send a private message to toolhawk
Ok bought a D2 knowing less than nothing about these , but can usually fix anything , bought for my own use on hunting property , put fuel in pony motor tank push starter started right up and ran fine , fuel tank leaked like a soaker hose , fixed tank , new lines, filter........ now no spark at all !!!!! am I missing or forgetting something ?? or did mag just die on me ? how or can I test ? Thanks !!!
Sat, May 10, 2014 10:24 AM
Thank you received: 51
File/clean the points. Oxidation of the contacts is a common problem.
Sat, May 10, 2014 1:42 PM
Dandy Dave
Send a private message to Dandy Dave
Did you Bump the shut off switch? be sure it is on. Dandy Dave!
Sat, May 10, 2014 5:51 PM
toolhawk
Reply to Dandy Dave:
points good and clean , rotor good still nothing , will try to pick up condenser Monday somewhere!!!! any other ideas , seeing that I run it myself I'm thinking condenser !
Sun, May 11, 2014 4:43 AM
Thank you received: 48
Reply to toolhawk:
Does the mag have the ground wire kill switch ?Even if switch is on check that the wire is not bare and grounding things out.
Ray
Sun, May 11, 2014 7:14 AM
Reply to Ray54:
Ray
Do a resistance check on the coil secondary. Should be about 6200 ohms.
Sun, May 11, 2014 7:25 AM
D4C Charlie
Send a private message to D4C Charlie
Make sure the little carbon contact in the mag cap is in place. Charlie
Sun, May 11, 2014 8:18 AM
toolhawk
Reply to D4C Charlie:
carbons in place , have tester how do I do the test , what will it confirm ? THANKS !!
Sun, May 11, 2014 9:00 PM
Reply to toolhawk:
Check between the coil lead wire and the brass contact for the for the distributor plate. If you get a "0" reading the coil wire is open.
If your meter can check capacitance the reading between the condenser lead and its case should be about 0.24 micro farad.
Sun, May 11, 2014 9:58 PM
Jim Davis
Send a private message to Jim Davis
If the above suggestions don't help, remove the wire from the kill switch to the mag (at the mag) and check for spark.
Mon, May 12, 2014 12:33 AM
mikedell
Send a private message to mikedell
Reply to Jim Davis:
I have a mag that was giving me issues as well after looking at everything I could, I wound up taking a heat gun and blowing inside the mag, after about 10 minutes of doing that, I gave it a try and boom, I had spark. Im guessing I had a small amount of moisture somewhere that I wasn't seeing. May or may not work but worth a shot.
Mon, May 12, 2014 12:48 AM
