D2 Maintenance Question
Gregness
Hey All,
I serviced my Cat last time I was at my ranch, but I forgot to check the lube in the finals. Looks like you check it and top it off with those big plugs on the back side of the housings. I do not have the tool, but it looks like a bolt can be made into the right size tool. Anyone know what size bolt I should weld on to socket or extension to create this tool?
Greg
Sat, Nov 5, 2016 3:20 AM
Bruce P
Thank you received: 33
1-1/8".
Bp.
Sat, Nov 5, 2016 4:35 AM
TOGNOT
Reply to Bruce P:
1-1/8".
Bp.
Or - just jamb two nuts against each other on the bolt. Put the wrench on those to remove the plug
Sat, Nov 5, 2016 4:38 AM
Paso Bob
Reply to TOGNOT:
Place one Crescent wrench into the edge of the plug and V of the plug and use another crescent wrench on the first crescent wrench and open it up...
Sat, Nov 5, 2016 9:58 AM
Oldrnu
Send a private message to Oldrnu
Reply to Paso Bob:
I just got a bolt with a slightly larger hex head and ground down the hex until it fit. Then grind a couple flats on the threaded portion and use a crescent wrench on that. The plugs usually aren't too tight.
Sat, Nov 5, 2016 11:29 PM
