D2 main Govner housing
Riverina d4
Send a private message to Riverina d4
My 5U gov housing has what appears to be a cork plug in this hole. Just wondering if it's normal and what the hole is for.[attachment=59612]20200705_120148.jpg[/attachment][attachment=59612]20200705_120148.jpg[/attachment]
Sun, Jul 5, 2020 9:10 AM
Thank you received: 91
Hi,
cork seals of the puller bolt threads in the outer end of the shaft so as to assist in removal of the Terminal Lever shaft in the housing.
SRB shows a bolt in use under the heading of Terminal Lever Removal.
Sun, Jul 5, 2020 10:40 AM
Riverina d4
Reply to edb:
Hi,
[quote="edb"]Hi,
Eddie B.[/quote]
Thanks for the reply Eddie. If you say all is good than I can relax. Happy Days
Sun, Jul 5, 2020 3:52 PM
Sf1066
Send a private message to Sf1066
Reply to Riverina d4:
[quote="edb"]Hi,
Eddie B.[/quote]
Glad you asked. I noticed that on mine too and was wondering. It appears I have injection and governor work to do soon.
Sun, Jul 5, 2020 9:49 PM
Reply to Sf1066:
the shaft hole is a blind threaded hole so the cork helps keep out dirt, rust and mud daubers. It was a common practice of Cat to cork such holes in many locations on their machines.
Mon, Jul 6, 2020 6:39 AM
