D2 main fuel tank breather detail - need help please!
Showing 1 to 10 of 16 results
Thank you received: 22
Could someone help me figure out how to repair the breather on my 5U seat tank. The tube that comes down from the main fill opening rotted off just above the fitting that screws into the tank. It "looks" like it was swaged inside that fitting but there must be more to it than than because I'm sure it would leak without some kind of goo or retainer. In any case, I don't need the internals to be original; I just want it to work without leaking, and without requiring me to leave the main cap loose so the tank can breathe, because I'm sure it'll leak diesel all over my new John Hahn seat.
Basically, the tube coming down from the top needs to pass through the bottom of the tank in a fuel-tight fashion. If I can accomplish that, the rest is easy
Wed, Jul 4, 2018 1:45 AM
Sounds like a pretty standard use of a slip fit ferrule and compression coupling. I really don't know anything about what sort of fitting is there through the bottom of the tank, but surely you can find a piece of copper or steel tube with the correct OD and a nut and ferrule to thread into the fitting from the bottom. I suppose you could use a packing instead of a compression ferrule and it might help to prevent cracking. Something like faucet stem seal graphited string?
Wed, Jul 4, 2018 3:24 AM
If I'm understanding you, the main fitting would internally take a compression fitting that the inner tube would pass through, and that's what would prevent diesel leaking out around the tube. That makes sense. Would hard copper be ok? It current has 1/4 steel but it's now too short so I have to replace it anyway.
Wed, Jul 4, 2018 3:36 AM
from memory, the seat tank breather is built into the tank cap and is held together with a central drilled bolt that holds a plate in-situ, the plate in turn holds a metal gauze type filter medium in a spiral groove cast into the cap.
Only tube I recall in the filler and screen area is a short guide tube for the dipstick/plunger--I stand to be corrected.
Wed, Jul 4, 2018 6:01 AM
Reply to edb:
I know what your referring to but I'm not that familiar. The parts book calls out a fitting that the vent screen screws in under the tank. That might be a compression type fitting for the tube and threaded for the vent screen.
Wed, Jul 4, 2018 6:26 AM
jumbo
Send a private message to jumbo
Neil, I sent you a pm.
I'm not afraid of hard work; I can lay down beside it anytime and take a nap.
Wed, Jul 4, 2018 9:42 AM
Reply to jumbo:
All, here's the arrangement:
[attachment=49688]IMG_5719.jpg[/attachment]
Tube runs from under the main cap down to outlet in bottom of tank:
[attachment=49686]IMG_5722.jpg[/attachment]
[attachment=49687]IMG_5720.jpg[/attachment]
Original main fitting that the tube passed through / into. Almost looks like it was soldered in place. Took a bit of heat and effort to get it out and that "stuff" looks suspiciously like lead / solder:
[attachment=49685]IMG_5723.jpg[/attachment]
Inside of fitting with some type of flare arrangement:
[attachment=49684]IMG_5724.jpg[/attachment]
What I want to replace it with. The large brass fitting would replicate the original with a compression fitting type of face internally, with a hole large enough for the 1/4 tube to pass through. The small brass fitting would be the other side of the compression fitting - the olive would fit in the middle. The small brass fitting would also have a 1/8 NPT so the breather could be screwed into it (breather is top right of photo)
[attachment=49689]IMG_5725.jpg[/attachment]
Wed, Jul 4, 2018 11:11 PM
Hi Neil,
thanks for the great pix of said breather arrangement, do not recall seeing one but, there it is, and not shown in my Parts Books.
Good to know that I have not wasted today and learned something new on these often surprising old Cats.
Best Regards,
Thu, Jul 5, 2018 8:25 AM
cojhl2
Reply to edb:
Hi Neil,
Best Regards,
I wonder what the point is of such a complicated breather arrangement when the cap as explained by edb works perfectly well.
Thu, Jul 5, 2018 8:43 PM
Reply to cojhl2:
I would guess that they thought that it would avoid any diesel spillage out the top of the cap and down the operator's back. But maybe, like the oil cooler, they decided later that it really wasn't necessary. This unit is 5U13753 so middle of the range I guess.
Thu, Jul 5, 2018 8:50 PM
Mike Meyer
Hi Neil, my D2 5U has a thin round flat steel plate that sits under the fuel cap to prevent fuel sloshing, does your tractor have that plate? My tractor is in the 16000's I reckon.
Regards
Mike
Fri, Jul 6, 2018 4:01 AM
