D2 main bearings ???
Showing 1 to 6 of 6 results
Mr. Hypile
Send a private message to Mr. Hypile
I am looking for .030 undersize main bearings for my D2, d311 motor. Or if they need to be made where can I get it done ??
Thu, Mar 26, 2015 7:30 AM
Mike Mahler
Send a private message to Mike Mahler
If you are unable to locate main bearings I can reline your old shells and machine them to spec for you.
Mike
My services shown at www.myspace.com/vintageengine
Thu, Mar 26, 2015 10:01 PM
Mr. Hypile
Reply to Mike Mahler:
Mike
Thanks Mike looks good how do I get ahold of you ?
Fri, Mar 27, 2015 4:49 AM
Reply to Mr. Hypile:
I believe this era machine ran the thick aluminium shells, with no Babbitt, on both the rod and main bearings.
You may need to make up bronze shells and Babbitt them.
Others have machined suitable aluminium bearing material to make their own shells. I think there was some discussion before Xmas about this and it seems from the discussion that Toyota pistons are very similar metallurgy to the Cat shells???
Fri, Mar 27, 2015 6:03 AM
Mike Mahler
Reply to edb:
He contacted me today and he thinks they may be aluminium and suitable tinning solutions for aluminium to babbit are either elusive or non-existant these days. Making new shells is not out of the question.
Mike
Fri, Mar 27, 2015 6:40 AM
Mr. Hypile
Mike
Thanks everyone for the help I think these will have to be made now if I can get the right material I will get them made.
Fri, Mar 27, 2015 6:54 AM
Online
Thank you received: 24
Mr Hypile,
have you checked with Cat? I picked up some of the 030 bearings I needed from Cat, and got the rest from a couple of parts houses - they're out there. The only one I couldn't track down was the front main, so I had that journal welded back up to std and there is a healthy quantity of std bearings available
Fri, Mar 27, 2015 7:24 PM
Earlcoate Charity Open Day
