d2 lubrication question
Showing 1 to 10 of 12 results
putsplut
Send a private message to putsplut
I've been getting my d2 ready for winter plowing and I think I'm down to one final lube point. I have a reproduction operator's manual for my 5u d2 so the pictures aren't very clear sometimes. I've been unable to find the flywheel clutch pilot bearing grease zerk. I also don't see it in my parts catalog. The only lubrication point I see is where the oil cup on top of the cover plate drains into the funnel for the flywheel clutch shift collar. With that, I have 2 questions:
1.) Where is that grease zerk for the pilot bearing?
2.) On an infrequent use machine, should I stay with the hour intervals in the operators manual for adding oil to the lubrication cups (such as the shift collar) or assume it also needs done after some number of weeks of sitting.
Sun, Nov 21, 2010 10:07 AM
STEPHEN
I remember it being near the rim of the flywheel, there is an access point on the right side of the flywheel housing. Turn the flywheel by hand until it lines up.
Sun, Nov 21, 2010 10:36 AM
Kelly
Reply to STEPHEN:
Here you go.
Check Here
Sun, Nov 21, 2010 12:55 PM
Reply to Kelly:
Here you go.
Check Here
On an infrequent use machine, you should oil it based on the theory that the oil has drained out from sitting. Give it a squirt or two in the oil cups prior to use. While the pony is cranking it, warming the cylinders is a good time. As far as grease points, those you could stay on the hour intervals due to grease doesn't drain away.
Sun, Nov 21, 2010 8:38 PM
putsplut
Reply to drujinin:
Thanks to all of you. I have a much better idea of where I'm supposed to be looking now.
It would appear the 7J tractors are set up slightly different than my 5U since the front-side access port in Kelly's pictures appears to be near the outside edge while mine sits very close to the block. And we'll just skip the discussion of me trying to pump grease into the plunger knob. :rolleyes2:
Sun, Nov 21, 2010 10:35 PM
ag-mike
Reply to putsplut:
put roller lube in there, grease dris up and gets hard.
goodluck.
Sun, Nov 21, 2010 11:47 PM
putsplut
Reply to ag-mike:
goodluck.
Still no love from the machine. On the front cover, I can watch the flywheel make a full revolution. I see occasional timing marks and some bolts on the outer edge - or at least the outer area of what I could see. Watching through the access cover under the air intake (on which the cover states that the grease point is inside), I see near the outside of the disk a row of teeth connecting the outer ring and the inner disk. From the pictures Kelly posted, I believe the outer ring is part of the flywheel. Again from the pictures, I believe the inner disk is either the rear pressure plate or the outer portion of the driving plate. I find no grease zerk on the face of the flywheel. I even felt along the outside of the flywheel while my wife turned the motor for me. You know I'm stumped when I'm bringing my wife out to the shop to help me! Where there ever any after-market pilot bearing that did away with the periodic grease requirements?
Mon, Nov 22, 2010 6:08 AM
the fitting may be gone, leaving only a tiny threaded hole. All the books I have show a 45* elbow fitting on the rear face of the flywheel. I had the one out of the 212 several years ago and what I remember about it was the fitting was countersunk, but none of the books I have show that, the fitting is simply screwed into the flat face of the flywheel in the diagrams. You need to scrape or brush the flywheel surface and find the hole which is probably packed with hard dry grease and clutch dust. I would carefully clean it with a drill bit to pull the crud out instead of pushing it on into the passage and eventually ruining the bearing.
The toothed part on the outer circumference is the flywheel and it meshes up with the driving plate of the tractor clutch (maybe a composition type or could be a lined steel disk). The same part would be the pressure plate of the grader which has an automotive foot clutch instead of the over-center clutch like the tractors have.
Mon, Nov 22, 2010 10:13 AM
putsplut
Haven't found the zerk hole yet, but winter has found me. I'll try again in the spring or sooner if we get a warmer snow-free spell. Thanks all for the help.
Thu, Dec 2, 2010 12:13 PM
putsplut
Reply to putsplut:
The weather was nice today and I didn't have to work. The zerk hole has been found, cleaned, re-zerked, and greased. Merry Christmas to all and don't eat the yellow snow.
putsplut
Fri, Dec 24, 2010 4:59 AM
Mike Meyer
Thank you received: 6
Reply to putsplut:
putsplut
My D2 4U has that zerk fitting on the clutch side of the flywheel, from memory there are two or 4 pre-drilled holes.
Merry Christmas
Mike
Sat, Dec 25, 2010 3:08 AM
| Kingaroy, Queensland
