D2 J series belly pan bracket template
Showing 1 to 6 of 6 results
Breadler
Hello everyone,
I have a belly pan, however I am missing the mounting bracket for the rear. I am wondering if anyone has one that they could trace, to create a template for me to fabricate one.
Thanks Much,
Breadler
D5C, D4-7U, D2-5U, D2-5J
Mon, May 4, 2026 4:34 AM
Grow
Thank you received: 5
I was once told that the Cat parts books were drawn to scale. What scale, who knows? I have played with the drawings and my printer to come up with results. If you can measure between bolt holes on the tractor and blow the picture up until you get the same measurement it should get you close enough to make a reasonable copy until the real part can be sourced.
Wed, May 6, 2026 9:05 PM
Busso20
Thank you received: 23
HI Breadler I will check out the one I have as a spare im not sure if it has rear mount with the box of bits I have
Wed, May 6, 2026 9:36 PM
Breadler
Grow, that was my first thought, as I understand they are scale drawings as well. Unfortunately the parts book is a side (edge) view of the plate.
Busso20, Thanks, keep me posted!!
Thu, May 7, 2026 4:47 PM
Busso20
Breadler, I checked my parts pieces only have the bottom plate with out any mount section or bracket looking item (Engine block is sitting on it), ill see if I can get pictures from under my machine to see if they help to locate bolt holes etc
Thu, May 7, 2026 9:50 PM
Busso20
Fri, May 8, 2026 9:31 AM
Busso20
Breadler the first picture I believe is the end bracket you may be chasing measurements from on the U shape bracket, the other end of belly guard has holes only picture in this post
Fri, May 8, 2026 9:36 AM
