D2 Inlet Manifold Setup
Showing 1 to 7 of 7 results
NZCat
Send a private message to NZCat
Hello Folks
Was running my D2-5U in the weekend and happened to notice that while the main is running there is air being drawn into the pony exhaust.
Somewhere in the dim recesses of my mind I recal that this is a real common "no-no" cause its effectively bypassing the aircleaner - am I right in assuming this ??
If it is a problem how do I fix it ? The seals at each end of the inlet manifold look OK, but replacing them looks like work !!
Foster
Foster Price
Southland, NZ
D2-5U #10200
Mon, Nov 9, 2009 7:11 AM
Those are the symptoms of a leaking heat exchanger tube in the intake manifold. The one that normally pipes heated pony exhaust to preheat main engine intake air. Got a service bulletin on it here somewhere, I'll try to find it and post.
Mon, Nov 9, 2009 7:35 AM
Bruce P
Thank you received: 38
Hello Foster; that was a common problem on farm cats around here. A quick and temporary fix was to plug the pony exhaust pipe with a cork or something that would seal tight, otherwise you'll dust the main.
Good luck,
Bruce
Mon, Nov 9, 2009 7:49 AM
OzDozer
Reply to Bruce P:
Good luck,
Bruce
The SM article is dated June 1, 1954 .. and here's a scan of it ..
[img]http://i33.tinypic.com/1zv8to1.jpg[/img]
Mon, Nov 9, 2009 8:24 AM
Reply to OzDozer:
Here's the one I was thinking of:
Mon, Nov 9, 2009 9:00 AM
shovel man
Very interesting article, was this only a problem on U series tractors or did it affect J models as well? next time I get my 4U going I'll check it.
Shovel man.
Tue, Nov 10, 2009 3:09 AM
Billy-
Send a private message to Billy-
Reply to shovel man:
Shovel man.
Yep J series D2's and D4 4G, 7J, 2T, 5T had same problem but had different manifold set up.
[img]http://img692.imageshack.us/img692/6373/manifoldcheckcaterpilla.jpg[/img]
Billy
Tue, Nov 10, 2009 4:01 AM
Shovel man.
Mostly applies to the "U" models after the early models that had the cast iron heat exchangers which were pretty much bullet proof but I suppose the cast iron could get ate out too. It's those thin wall heat exchanger tubes with bellows like the 7U5349-up that are more of a problem.
Tue, Nov 10, 2009 7:13 AM
