D2 Injector removal
D2 Injector removal
Showing 1 to 10 of 41 results
Uncle Rich
Send a private message to Uncle Rich
Ok guys, It's now finally warming up in Wisconsin and enough snow has melted off my D2 4U05644 for me to get back to work. Last Fall I determined I needed to pull the injectors out and have them tested, so I studied the shop manual and read some posts on the issue. It seemed easy until I removed the fuel lines and started turning the injector holdown nuts only to find the retainer cap turning and coming out. When coolant started gushing out I knew it was time to re-tighten the nut and go back to the book and the bulletin boards. I still have several questions.
a. Is it possible only the nut and the retainer cap is turning, or is it most likely the whole Pre-combustion chamber is coming out?
b. Is it normal that coolant comes out, and needs to be drained first?
c. Can the nut be heated hard and fast to make it come loose without anything else turning or the cap o-rings being damaged?
Studying all the drawings and pictures I can find leaves me baffled as how the chamber, retainer cap, and injector nut are assembled. The chamber is obviously screwed into the head, but the hold down nut seems to be threaded into the chamber and the retainer at the same time. There is no way to hold the retainer cap from turning. Without having one of these in my hand it's hard for me to understand how it works. Iv,e read many old posts on it and the whole topic now seems way more complex than the shop manual suggests. Any clarification or advice would be helpfull.
Thank you.
Thu, Apr 25, 2013 10:01 AM
injector hold-down nut screws into the chamber itself, not the retainer that seals around the top of the chamber. So, probably, the whole chamber is coming out and bringing the retainer with it.
Coolant will come out (and also leak into the cylinder if the PC chamber screws out of the head). However, normally the chamber and retainer if it is a separate piece, will stay put while you unscrew the injector hold-down nut.
I would not heat the nut. If it's coming out with the chamber or the retainer or both, just drain the coolant, unscrew whatever wants to come out and then separate it later. An impact wrench might help to rattle the hold-down nut loose if you end up with a loose PC chamber with an injector and hold down nut stuck in it. Probably could clamp it in a vise with blocks of soft wood etc to hold it while removing the nut and injector.
You will need a PC chamber installation tool set to replace the chamber and retainer with new seals.
Thu, Apr 25, 2013 6:20 PM
Uncle Rich
Thanks for the reply. I guess I have another question then.
In the drawing the cap seems to be threaded onto the nut and the nut is also threaded into the chamber. If all is perfect, and comes apart as designed, does the cap stay in the head, or does it come out with the nut as it is removed from the chamber? There seems to be no way to hold the cap in place while removing the nut. If it would stay there, no coolant would be lost.
I'll drain the coolant and just let things come apart, then deal with the remains I guess.
Thu, Apr 25, 2013 7:15 PM
Threads in the cap (CAT callls it a retainer) are a larger size than those in the upper end of the PC chamber. The cap should stay in place, usually shows no inclination to move when removing the injector hold down nut. It will come out with the precombusion chamber and frequently will go back in with the chamber as long as you do not break the bond of rust and dirt between the two to replace the inner o-ring seal as you should. I didn't know for a long time that the retainer was a separate piece having removed several chambers from our D6 that stayed together.
Newer PC chambers are usually a single piece design with the top surface of the retainer a bit taller to allow for differences in head castings etc. This also allows room for a glow plug port to be drilled and tapped into them, angling in from the outer edge where it would have passed from the old retainer, through the water jacket and into the precombusion chamber if one had attempted to drill one into that style.
Fri, Apr 26, 2013 12:48 AM
Thank you received: 95
Hi Rich,
the scan below may explain the set up better.
The retainer is just sitting in place with the "O" ring seals BUT is held in place by the flange on the injector retaining nut.
As CCJ said the threads in the retainer are used with a puller bolt and spacer to remove it--shown in the scan.
Often when the pre-chamber unscrews when trying to remove the injector--loose pre-chamber-- it can be a sign of an overheated engine and/or cracks in the head at the pre-chamber hole.
Hope this helps.
Fri, Apr 26, 2013 6:19 AM
restore49
Reply to edb:
Hi Rich,
Hope this helps.
The crush washer (copper) at the head -chamber joint will need to be replaced. Same thing happened to me last week when backing off the 1 in. retainer nut. Combustion chamber 200 FT. lbs retainer nut 100 Ft. lbs. Bob
Fri, Apr 26, 2013 7:49 AM
Thank you received: 78
Reply to restore49:
When torquing the chamber, do you lube the threads with copper or oil or just leave them dry?
Fri, Apr 26, 2013 9:15 AM
My vote would be to anti-seize them with a copper type if using copper seals or any type anti-seize if using the soft steel type.........AND drop the torque value to 150 foot pounds or so.
I expect using lubrication of any type and using the standard torque value might result in stripped threads.
Fri, Apr 26, 2013 10:15 AM
Uncle Rich
Eddie
Thanks for the clear pictures. Now I can see what is going on. A picture is worth a thousand words. Looks like I,ll need to find a pre-comb tool kit as well. I,ll drain the coolant again this weekend and see what happens. I hope I can find the tools to put it back together. The search begins.
Neil,
I would think Never-Seize would be an appropriate modern day product for that app.
I,ll post the results?
Thanks again.
Fri, Apr 26, 2013 10:23 AM
Reply to Uncle Rich:
Eddie
Neil,
Thanks again.
Good - that's what I was thinking. I think I have a leaking chamber on my 3J - if so, I'll pull them all. What are folks thoughts on copper vs. steel? I'd lean toward copper as conforming to irregularities better.
Neil.
Fri, Apr 26, 2013 6:14 PM
Neil.
from memory the steel washers are made of very soft ingot iron to enable them to conform to the irregularities you mention. They are also less prone to loosening off due to being more heat stable.
They also recommend torqueing to 200 lbs ft but, I would be wary of copper coated threads stripping on these old heads--previous torque for copper gaskets was 150 lbs ft. Maybe just use oil at the new higher torque.
This data from Service Bulletin Sept 19 1956.
Sat, Apr 27, 2013 8:59 AM
