D2: I Tried to bite off more than she could Chew, bent the Cutting edge plate?
Showing 1 to 9 of 9 results
G2D2
Send a private message to G2D2
Dont know if this cutting edge was loose and I missed it or what the deal is, you can see in the pictures half is tight and half is not, I did stall her and took a chunk of dirt out where I could not see the elevation go up real quick so think I bent this edge, looks like it has been done before on the ip side edge.. Anyone know where to get these new bolts and what they are called?  Any tips on blades and cutting edges in general? Had to cut this side bolt off and the main blade metal behind it is really thin!  [attachment=68906]Copy of IMG_4176.PNG[/attachment] [attachment=68908]Copy of IMG_4171.PNG[/attachment] [attachment=68909]Copy of IMG_4170.PNG[/attachment] [attachment=68910]Copy of IMG_4169.PNG[/attachment]
Mon, Sep 12, 2022 3:04 AM
bruce oz
Thank you received: 23
 [attachment=68915]4.JPG[/attachment]Caterpillar Cutting Edge Bolt, 4F3654 ?
Mon, Sep 12, 2022 4:28 AM
Thank you received: 73
Reply to bruce oz:
You can get the cutting edges, bolts, and nuts from your Cat dealer. I bought a new set for my D2 blade a couple of years ago
Mon, Sep 12, 2022 6:09 AM
D4Jim
Us Redneck farmers call them plow bolts!!
Cats Forever
Mon, Sep 12, 2022 10:05 AM
G2D2
Reply to bruce oz:
 Bruce Oz!  could not figure out why my parts catalog did not have the schematic come to find its just the d2 tractor parts book not the bulldozer !  Thank you for the kind post!
Mon, Sep 12, 2022 11:25 AM
G2D2
Great to know, thank you Neil!
Mon, Sep 12, 2022 11:35 AM
gauntjoh
Librarian
Thank you received: 5
Reply to G2D2:
Hi G2D2,
We have manuals for 2A and 2S (D2) dozers in the members library.
Membership costs from just $44 per annum and supports this website.
 [attachment=68921]Screenshot (4😎.png[/attachment]
Mon, Sep 12, 2022 12:35 PM
Thank you received: 54
Reply to gauntjoh:
Hi G2D2,
the bolts are called plough bolts any good bolt supplier will have them or can get them. any place that sells farm implements will have them too. and smear the with a little anti-sieze when installing makes life easier next time.
Mon, Sep 12, 2022 1:14 PM
74A6C
Send a private message to 74A6C
Reply to trainzkid88:
Plow bolts are what I've always known them to be called, no matter if they're on a CAT tractor, Deere grader or Deere mold board plow. I've had decent luck building up frogs (where your wearable edge bolts) using higher tensile welding rods. 8018 and up, by being careful and lots of use of a 7 inch grinder and a helluva bunch of patience. And always put a full set of new bolts in the particular wear piece you are replacing or turning.
Tue, Sep 13, 2022 10:17 AM
74A6C
Reply to 74A6C:
As always Mr. Gaunt is correct, a membership is nearly invaluable with it's small fee. Parts book availability is well worth the cost.
Tue, Sep 13, 2022 10:20 AM
| Kingaroy, Queensland
