D2 hydraulics seeping down...
jdkoller
Send a private message to jdkoller
I have a D2 with a 2S blade and a 44 pump. There is a little leakage from the cylinders but I am shocked at how fast the blade will fall without operating the lever. I'm guessing that it takes much less than a minute for the blade to go from its highest position to the ground. Hoses and external connections appear fine. What is the most common cause? Cylinders? Seals? Specific component in the pump? All of the above?
Thu, Jun 2, 2011 8:35 PM
I would say cylinder piston valves or seals on piston. One bad cylinder and the dozer will leak down symetrically, you can't tell which by looking at it since the oil will equalize through the T connections in the lines where they divide to go to each cylinder.
If you have a diverter valve on the fender, you can lock it off and take the #44 out of the picture if it still leaks down with the diverter turned. If it holds with the diverter locked off, I believe that eliminates the cylinders as the source of the problem.
You can try to identify which one by raising the dozer blade and then shutting off the engine so you can hear/feel the lines and the cylinder for moving oil. Also can cap off the lines if you can find some kind of caps. Have to have a jack or hoist to do it that way to allow you to take the lines loose and install the caps before letting the weight go on the cylinders.
Fri, Jun 3, 2011 12:33 AM
jdkoller
Good ideas. Thanks for the tip. I'll try the fender valve first and see if the cylinders still seep.
Fri, Jun 3, 2011 6:37 AM
rditz
Send a private message to rditz
Reply to jdkoller:
i had a similar problem with the tilt cylinders on my 955. when I took them in for a rebuild (because I felt they were bleeding by) the hydraulic shop found that one of the cylinders had a packing steel ring that had shattered into 6 pieces. he said i was lucky that the bore was not ruined...
you may have 1 or both cylinders bleeding past the packing.
rod
Fri, Jun 3, 2011 8:29 AM
