If you can get a shaft and the parts that go to the front pulley, I can supply you with a new splined coupling if yours is worn. Most are worn to very thin splines on that coupling.
1.250 x 10 spline is the correct size for the #44 drive shaft coupling.
Shaft and couplings are available from:
http://catalogs.hubcityinc.com/farmrev/completelist.html
