D2 hydraulic o rings
MTD2
Send a private message to MTD2
I am in need of the part number and or size of the o rings for the hydraulic lines on my d2. I have several universal o ring kits and none of them seem to be thick enough to seal. If any of you have a cat part number for these would be great! Is there 8 that are the same size?
Also need the number the the same o rings on the d4 7u hydraulic lines. They are a little bigger. Thanks.
Sun, Feb 3, 2019 11:06 PM
5F1678 for 3/4" lines .990" dia.
5F9657 for flange fittings
4F7391 at cross tubes
At crossover valve 4F7952
5F7054 for 1/2" lines .740" dia.
Sun, Feb 3, 2019 11:19 PM
MTD2
Thanks Rome. I will get some ordered. No sense having a leak when they are so easy to get to!
Mon, Feb 4, 2019 7:11 AM
Reply to MTD2:
Your welcome. Correct!
Mon, Feb 4, 2019 7:55 AM
| Kingaroy, Queensland
