D2 How to bleed the fuel system?
Showing 1 to 10 of 24 results
Douglas
Send a private message to Douglas
I just purchased a 1949or 50 D2. It ran fair to get it loaded on the trailer. Once I got it home I noticed it wasn't running very smoothly. I checked the fuel and it was old. Drained all the old fuel and change the sock filter. Yes I filled the filter housing with new fuel before I installed them. Now I can't get it to fire off. I tried to bleed the air from then number one line with no luck. I am new to this but really like working on this old iron. Any help would be greatly appreciated.
Thank You
Douglas
Tue, Aug 7, 2012 8:10 AM
oldogyou
Send a private message to oldogyou
when you say you bled no 1 line was the pony motor runningg and turning the main motor? as you need to open the lines or the bleed screws at the bottom of the injector pump and or the lines from the pump just loosen them a couple turns is enought. Then run the pony motor with the settings levers in the run position until fuel comes thru all the lines then tighten them down one at a time and it should start may take a little loosening then running but sooner that later it will fire off
oldogyou
Tue, Aug 7, 2012 8:22 AM
SpragueM
Reply to oldogyou:
oldogyou
First you need to bleed the towers that the sock filters are in. Then the individual pumps on top of the injector housing also have a bleed screw. Lastly the injectors themselves.
Removing the fuel tank cap and fitting an old inner tube over the opening (with the fill valve) will help considerably. Cut the inner tube, hose clamp it over the tank opening and apply 5 psi. This will force fuel through the filter housing and into the injector pump.
Matt
Tue, Aug 7, 2012 9:05 AM
Catmandu
Send a private message to Catmandu
Reply to SpragueM:
Matt
SpragueM,
I learned something new today👋
CMD
Tue, Aug 7, 2012 10:52 AM
oldogyou
Reply to Catmandu:
SpragueM,
CMD
So did I, never after all these 20-30 years of fighting fuel filter replacement and air ,I learned to use something simple like an old inner tube to make the job go so much easier I will remember that trick from now on.
thanks for the tip
Tue, Aug 7, 2012 11:12 AM
steeltracs
Thank you received: 5
Reply to oldogyou:
thanks for the tip
I use an extra fuel cap that I threaded in an air valve stem in the vent hole and apply air pressure with a tire gauge.
Tue, Aug 7, 2012 11:51 AM
oldogyou
Reply to steeltracs:
yes but I can use the innertube idea on any diesel ,as a professional, I am always looking for new ways to do things, and this one seems like its so simple should have thought of it myself.thanks again for the idea......
Tue, Aug 7, 2012 12:11 PM
Dandy Dave
Send a private message to Dandy Dave
Reply to oldogyou:
Geeee Wizzzz. And I thought every old Cat man knew that trick. First time I saw it was on a D7-E about 20 years ago. About 45 years ago my grand dad had a similar valve on a 4 cylinder Wisconsin that was on a New Holland haybaler. Those engines were notorious for vapor locking on a hot day in the hayfield. Dandy Dave!
Tue, Aug 7, 2012 7:57 PM
Steve A
Reply to Dandy Dave:
1 more tidbit, B sure to have the throtle open for fuel (and air) to flow
I 2 learned the inner tube trick on this site
Tue, Aug 7, 2012 8:08 PM
7upuller
Reply to Steve A:
Hey gang,
I have been called to help on a few friend' s Cats, to get them started. They always tell me that it ran out of fuel and then they put a couple of gallons in it. The first thing I do is add at least 10 more. They fired right up, after proper bleeding. Make sure you have a good amount of fuel in it. The compressed air trick is a good one, as long as fuel is in it. Just make sure your not just putting more air in the system. LOL Would the Duct tape work better, or the Bailing Wire here. LOL
Tue, Aug 7, 2012 8:52 PM
rjh-md
Reply to 7upuller:
Hey gang,
I have always had sucess bleeding the fuel systems ,by frist filling the filter housing full with fuel and then losening the injector lines at the cylinder head ,and crank over the engine until I get plenty of fuel leaking at the head ,then tighten each line after tightening 2 lines the engine will run while you tighten the remaining lines
Tue, Aug 7, 2012 11:23 PM
