D2 Fuel pressure
D2 Fuel pressure
Showing 1 to 6 of 6 results
Pioneer1930
Send a private message to Pioneer1930
Hello, So I posted a while ago about my fuel pressure gauge not reading during startup after a long restoration. The machine runs good, responsive, etc. I do not have any pressure reading at all. I figured my gauge was bunk as it was a ebay purchase several years ago so I have been running it while I do some other things on my blade. Today I decided to get to the bottom of it. I disassembled the gauge from the fuel tower and tested it at 15lb and it came right up to center. I then pulled the filters and inspected the housing, bleeder etc for any leakeage etc. nothing. As well as this thing runs, for the life of me I cannot seem to find why I'm not seeing a proper indicated pressure. I reassembled the gauge line and remounted it and before I reinstalled the filters I gave it another 15lb and the gauge came up to center again. So it appears all my pathways are clear. Any suggestions!!! My previous flight training makes it impossible for me to run a machine with a faulty gauge.........:usa2:
Sun, Jan 22, 2017 12:46 AM
Thank you received: 78
If yours has a pipe from the tower to the gauge, did you confirm that the pathway from the chamber to the gauge is clear?
Sun, Jan 22, 2017 1:14 AM
is the top gasket in the filter housing in the correct orientation? if wrong it can block off fuel passages.
Sun, Jan 22, 2017 2:19 AM
Pioneer1930
Reply to dpendzic:
I did verify my gasket orientation and my passage openings. I just went back out to the shop and installed a different gauge. It appears to lift the needle up about 20% when running at tad more when I open it up. Before I did this I got out my books and removed the bypass assembly at the bottom of my pump to verify it wasn't stuck open or something weird. Nope, nice and clean, rubber seal and spring in mint condition, not a bit of debris or sediment in the line either. So at this point I'm guessing my pump is probably at the bottom of its operating range? I'm not sure what else it could be. If that is the case would anyone know right off if this is available? Hope fully the cost is under what I paid for the machine! 😖mile:
Sun, Jan 22, 2017 2:40 AM
oldbeek
Reply to Pioneer1930:
On my 12 grader, i had a similar problem. Took the pump off and found gears in bad shape from pumping dirty fuel. The end plates were worm also. The gears were .006 shorter than the housing. I lapped the end plates with sand paper till they were flat. Then i lapped the center housing until the end clearance was .002 total. this brought my pressure up to 20psi with (stretched spring) even with very worn gears.. I had more time than money also. I can not beleive there is not a in line filter between the tank and pump. I cut the 1/2 inch line an added a Baldwin in line filter screen. $12.00 item.
Sun, Jan 22, 2017 3:27 AM
Reply to oldbeek:
I'm doing that too. I have a "regular" spin-on fuel filter that I'll fit under the fuel tank (it'll get knocked off I'm sure...) for this purpose.
Sun, Jan 22, 2017 4:56 AM
if the diesel starts fine I wouldn't worry to much about the lack of pressure on the gage---if it works it works!!! 😖mile:
Sun, Jan 22, 2017 5:28 AM
