D2 Fuel Cap - Stuck
D2 Fuel Cap - Stuck
Showing 1 to 10 of 13 results
Outbackrider
Send a private message to Outbackrider
I'm needing some ideas on how to get my D2 Fuel Cap loosened.
It's aluminum.
It doesn't look cross-threaded, guessing it is corroded/rusted on.
I've soaked it with CRC Freeze off, and PB Blaster, and
hit it with a little bit of heat. I've turned the tank upside down to let the
small amount of diesel seep out.
I've rapped the top with a wooden block and hammer, worried, I'm going to
break the two extruded ribs off. Can't get it to loosen.:frusty:
Any thoughts...thanks.
Wed, Oct 19, 2016 6:55 AM
Try a chain wrench?
Wed, Oct 19, 2016 7:23 AM
Bruce P
Thank you received: 40
If it were mine I would take two medium size ball ball peen hammers, one for each hand, and strike the cap multiple times all the way around, with each hammer 180 degrees from the other one. Time it so the the hammers hit at the same time. Don't go crazy with it, just strike a little harder than a tap. make a couple rounds and try to unscrew it.
Good luck
Bruce P
Wed, Oct 19, 2016 7:25 AM
Thank you received: 78
Reply to Bruce P:
Good luck
Bruce P
I had the same problem. I just worked at it for days, not hitting it too hard. It eventually capitulated... You could also try lightly heating the cap e.g. with a plumber's torch from a few inches away and then spray your penetrating oil in there immediately. It will loosen, it just takes LOTS of time
Wed, Oct 19, 2016 9:27 AM
Not smart using an open flame around the vented fuel cap.
I use a plumbers strap wrench so's not to bugger up the aluminum but the chain wrench will also work. Get some anti-sieze on there to prevent future problems once you get it loose..
Wed, Oct 19, 2016 9:41 AM
[quote="Old Magnet"]Not smart using an open flame around the vented fuel cap.
I use a plumbers strap wrench so's not to bugger up the aluminum but the chain wrench will also work. Get some anti-sieze on there to prevent future problems once you get it loose..[/quote]
Fuel tank was dry and devoid of fuel / fumes.... Of course, a fellow should take appropriate precautions
Wed, Oct 19, 2016 7:11 PM
Outbackrider
Thanks for the tips, I knew there had to be some experience with this issue
on this forum.
You guys are great.
Wed, Oct 19, 2016 7:34 PM
Oldrnu
Send a private message to Oldrnu
Reply to Outbackrider:
on this forum.
You guys are great.
Just curious, has it been on there a long time or did it just get over-tightened?
Wed, Oct 19, 2016 11:06 PM
Outbackrider
Reply to Oldrnu:
I'm going to guess it's been on for about 8-10 years.
It's a machine we bought and rescued. Came out of a field, track was off, doesn't
run, but I've got plans to make it a runner.
Just time and money...as they say.
Thu, Oct 20, 2016 1:36 AM
Pictures are always welcome!
Thu, Oct 20, 2016 7:03 AM
Gregness
Mine sure has a tendency to want to get cross-threaded, would not surprise me if that or generally bunged-up threads is the issue.
If it is safe, the aluminum should expand much more than the steel tank if heated carefully...
Greg
Thu, Oct 20, 2016 10:45 PM
