D2 flywheel removal from pony motor
rlitt
Send a private message to rlitt
I am finally breaking down my early version 5U to replace the clutch plate. The fly will on the pony motor needs to be removed due to it not making the Clarence on the clutch housing. Do I need to pull her for this?
Tue, Sep 25, 2018 5:41 AM
restore49
Believe you do remove. Use the two threaded holes in the flywheel to pull - DO NOT use a puller that grabs the outer lips of the pulley edges.
Tue, Sep 25, 2018 6:50 AM
old-iron-habit
Reply to restore49:
Also a good rap with a hammer on the end of the puller while under tension usually helps.
Tue, Sep 25, 2018 8:23 AM
TOGNOT
Reply to old-iron-habit:
you can search my old posts about removing a balancer on a d6 9U. ( others too, I'm sure)
you can make a puller with a bottle Jack and some long bolts
Tue, Sep 25, 2018 8:37 AM
rlitt
Reply to TOGNOT:
Ok, figured it out. The pull holes were plugged up with dirt. I see it now. Thanks for the replies.
Tue, Sep 25, 2018 8:46 AM
