D2 Final Drives
D2 Final Drives
doubleclutch
Send a private message to doubleclutch
I'm looking at a D2, but it appears to have broken teeth on the final drive on the right side. I can get a parts machine, but I need to know if the final drives are the same on serial number 5u15287 and 3j4387sp. Thank you.
Sat, Apr 20, 2013 9:17 AM
josh
Thank you received: 13
The basic answer is No, there are some parts in the final drive assembly that are the same, but the bull gear and pinion are different, and a complete swap of the assembly will not work either, as one is wide and the other narrow.
Sat, Apr 20, 2013 11:07 PM
doubleclutch
Reply to josh:
Thanks Josh.
Does anyone know of any good place to possibly find a final drive bull gear in western Canada?
Sun, Apr 21, 2013 1:37 AM
rotorbob
Send a private message to rotorbob
Reply to doubleclutch:
Thanks Josh.
i have bull gears that will fit your D2,i am in ca. ,a little far, but if u are unable 2 find one. bob
Sun, Apr 21, 2013 3:09 AM
doubleclutch
Reply to rotorbob:
Thanks Bob. I will definitely keep you in mind. You just may hear from me in the future.
Sun, Apr 21, 2013 5:09 AM
mog5858
are you looking for the U or the J final drive? there a auction sale coming up this summer just in side Manitoba that has lost of U d2 parts the sale is not till aug i have a 5j parts trator that could work as well.
Sun, Apr 21, 2013 10:02 PM
doubleclutch
Reply to mog5858:
Hi mog, if I purchase the D2, it is a 5U final drive I will be looking for.
Sun, Apr 21, 2013 10:46 PM
josh
If you are going to swap parts, the 5J bull gear changed to the 1F9824, same as used in the U series at 5J6159, if the 5J is prior to that Sn you could swap the whole final drive assembly.
Sun, Apr 21, 2013 11:15 PM
gemdozer
Thank you received: 24
Reply to josh:
I have 2 final drive gears 1f9824 for d2-5u with 64 teeths and am located near MONTREAL CANADA
Mon, Apr 22, 2013 4:30 AM
| Kingaroy, Queensland
