http://www.filejumbo.com/Download/D2684D060DB29B78/
hello mcarp,the link above has the info from the manual ,when the window open click on download ,bruce oz
did it move enough to get the wedges in, the final will move 1/8 to 1/4 and stop if the clutches are stuck. if this is the case try heat on the drum and rock the final from side to side, your odds are about 50/50
If it hasent moved at all you might have missed the bolt in the bottom that taps into the final case
thanks guys, we tried pulling it off all together but didnt go so then we took the sprocket and seal out . there seems to be two different housings on this one for the final and one for the steering clutch. but neither one will come lose we will work on it for awhile and report back thanks for the help.
I have limited experience, just did one a month ago. Mine would not move at all, I pounded an old putty knife in the crack and worked it around until I covered all of the mating surfaces. It then moved much easier and was able to work from a putty knife to a screwdriver to a crowbar to a digging bar. I think the gasket was initially holding things together. The clutch discs were rusted away and the splines on the brake drum were notched so the discs would not slide easily.
