D2 fan bearing
D2 fan bearing
Showing 1 to 10 of 12 results
Thermodyne707
Send a private message to Thermodyne707
I need to order a fan bearing for my D2 5j3705, what is the CAT part number?, reason being the fan has a wobble, thanx , rich
Thu, Mar 27, 2014 7:33 AM
Mike Meyer
Thank you received: 6
My D2 5J Parts Book shows two bearings, both P/N 1B4107, plus seal 1B2346
Mike
Thu, Mar 27, 2014 8:54 AM
Thermodyne707
Reply to Mike Meyer:
Mike
CAT no longer has those numbers in the system, I googled those numbers and I found that company called regal corporation has both the bearings and the seal
Thu, Mar 27, 2014 11:35 PM
Reply to Thermodyne707:
1B4107 crosses to a Bower/BCA #205
1B2346 crosses to a National #450059
Fri, Mar 28, 2014 12:25 AM
I expect the problem with the part numers as far as the CAT system is concerned is that there are not enough digits. Can't remember how they need to be done, but adding some zeros in the correct spots will make a lot of the older part numbers work. Maybe someone else will chime in here.
Regal is a good source, glad they have the parts. They are slowly discontinuing parts for the older stuff, but some bearings and seals, should be available for the forseeable future!
Mike Meyer
My local Cat Dealer here in Australia lists them as 6B1124 Bearing, in stock, $38.82, and Seal 7M8930, in stock $7.31
regards
Mike
Fri, Mar 28, 2014 3:48 AM
Thermodyne707
regards
Mike
Went to my local parts store today and got the 205 bearings ,but I got the sealed version , and also the seal number has been changed to 470059, thanx for all of the help again Guys!!!
Fri, Mar 28, 2014 4:22 AM
Original replacement would be an open bearing.
http://www.ebay.com/itm/BCA-Bower-National-Bearings-Federal-Mogul-205-Bearing-/121154814476?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c3563c20c&vxp=mtr
Fri, Mar 28, 2014 5:04 AM
Thermodyne707
It was a spur of the moment thing to go with the open face bearing, installing the bearings and seal is this weekends project along with sending out the radiator to get cleaned and a couple small leaks in it repaired and the overflow tube re soldered to the tank.
Fri, Mar 28, 2014 5:22 PM
Thermodyne707
Correction,,it was a spur of the moment Togo with the SEALED bearings
Fri, Mar 28, 2014 5:23 PM
Just pop out the seals which will be next to the grease resevoir. Most of them can be taken out with a pocket knife in about 10 seconds.
Fri, Mar 28, 2014 8:38 PM
