D2 engine parts
D2 engine parts
oldtanker
Send a private message to oldtanker
I may be going to look at a D2 with a stuck engine. How had is it to find engine rebuild parts?
Rick
Wed, Jun 27, 2012 12:29 AM
zootownjeepguy
Hi, A D2 with a stuck engine could be the beginning of far more problems. I had a D2 with a bad pony and a stuck engine. The engine broke loose without too much fuss but I discovered that the Valves & Seats were rusted out and needed to be replaced and also that the Rings were stuck in the grooves. After several years of collecting parts I ended up selling the project and bought a different D2 in better shape. If the machine has been sitting outside I'd be cautious.
If the Engine is known to be stuck I would advise checking the Steering Clutches (tow the tractor and make sure they release when you pull the levers), Brakes and Main Clutch before going any farther. All this is repairable and parts are readily available but the cost adds up faster than the National Debt.👍
Rich Salvaggio
D2 5U9917
Wed, Jun 27, 2012 2:32 AM
oldtanker
Reply to zootownjeepguy:
OK thanks for the info
rick
Thu, Jun 28, 2012 5:25 AM
microlink
Send a private message to microlink
Reply to oldtanker:
rick
PRICE, clutches and undercarriage. If they are all good, big chunks cost less than individual parts. Look for a complete engine or a whole donor tractor with a bad U/C.
Thu, Jun 28, 2012 9:41 AM
