D2 engine oil disappearing fasdt
Showing 1 to 10 of 12 results
Jim Davis
Send a private message to Jim Davis
I put 2 gallons of motor in my D2 5U today to bring the level up to what I thought it should be with the engine stopped. I ran the machine for maybe 15 minutes and had to shut down because a hydraulic cylinder clevis let go.
Fixed the clevis and was going to start up again. Checked the oil and it was down below the "low" with engine running mark.
I could see no evidence of where it had gone. The machine had sat in place running for 5 minutes or so while I looked at the clevis. But there was no oil on the ground anywhere.
Could a gallon or two leak out the rear main seal into the clutch housing in 15 minutes? I will pull the plug tomorrow, but I'm curious tonight.
Jim
Sat, Nov 5, 2016 6:50 AM
rmyram
if your breather is plugged it can push oil into the clutch housing, pop the top off the clutch housing if it is a dry clutch and you'l know in a hurry, don't do it with the engine running.
Sat, Nov 5, 2016 7:36 AM
Jim Davis
Reply to rmyram:
I took the breather/filler casting off the tractor so I could take it home to clean. I got the top outer shell off the breather, but that leaves another metal shell with the filter inside it still attached to the lower shell/casting. Does that come apart for cleaning? It does not seem interested in moving....
Jim
Sun, Nov 6, 2016 1:19 AM
Oldrnu
Send a private message to Oldrnu
Reply to Jim Davis:
Jim
If I understand your first post correctly, you put in the oil when the engine was cold and not running then checked it again after only 5 minutes, the engine was still fairly cool and a fair amount of oil was still up in the engine. That would cause a lot of difference on the dipstick.
Sun, Nov 6, 2016 1:38 AM
Jim Davis
Reply to Oldrnu:
Actually, I didn't check the oil until I was going to start it up the next day. It's still down a lot, after that short run.
I got the breather all apart and washed it well in gasoline. Now to put it back on the machine and take a look in the clutch housing.
Thanks to both of you for your help.
Jim
Sun, Nov 6, 2016 1:56 AM
Reply to Jim Davis:
Jim
Jim---did you ever sell that winch you had? what about the parts machine it was on?
Sun, Nov 6, 2016 3:48 AM
Jim Davis
Reply to dpendzic:
Sold the winch. Still have the parts machine. (I turn both engines nearly every day to make sure they don't stick😉 Thinking about overhauling the pony on the parts machine. The pony on my user dumps oil as if it had no seals and has at least 1/8 inch of end play on the crank.
Jim
Sun, Nov 6, 2016 5:53 AM
Jim Davis
Reply to Jim Davis:
Jim
I couldn't see well into the bottom of the housing, but the clutch disk was dry, so I don't think much oil could be in there.
This time, i did get a couple of hours out of the machine before the oil got too low. Something has changed, because the first few hours I used it ( a few years ago and only an hour or three per year since) it only used a quart or two per session.
Mon, Nov 7, 2016 6:36 AM
mrsmackpaul
Reply to Jim Davis:
does it have Indians ??? as smoke a lot
If it isnt going out the exhaust or leaking on to the ground or in the bell housing I dont think it leaves many other places to go but I could be wrong
Paul
Mon, Nov 7, 2016 6:46 AM
7upuller
Reply to mrsmackpaul:
Paul
Hey Jim,
Add oil when warm to full mark. Go put it to work, hard. Go pull a disc or another implement that really makes it grunt. Go work it for at least two hours. These diesels that sit a lot and don't get worked hard seem to slobber a bit. I suspect your rings need a good work out.
Glen
PS... I always check my oil when parking. I let the machine cool down a bit at idle and use that time to check the oil warm.
Mon, Nov 7, 2016 7:30 AM
Jim Davis
Reply to 7upuller:
Hey Jim,
Glen
Well, it doesn't seem to smoke much when in use, just a little smoky at start up.
I guess it may be slobbery rings. The only way I can work it hard is dozing. Don't have an implement big enough to make it work. My little 7' JD KW disc won't do it unless I was pulling it in soft deep-tilled soil--don't have that.
Mon, Nov 7, 2016 9:25 PM
Veerkamp Open House 2025
| Placerville, CA
Stradsett Park Vintage Rally
Chapter 2 The Link Club's AGM
