D2 drawbar removal
D2 drawbar removal
Old_n_slo
Send a private message to Old_n_slo
Before I pull the 4 large nuts holding on that crossbrace in hopes of removing the drawbar, is it as simple and removing the 2 fasteners that run parallel (and on top) of the drawbar and then the pin drops down?
Wed, Jul 11, 2012 10:05 PM
Maybe if your lucky.....my findings have been those two retainer pin bolts are often froze up along with the main pin. Better to unbolt the bracket from the case and deal with the pins on the bench....or not at all.
Wed, Jul 11, 2012 10:21 PM
Old_n_slo
...my drawbar, as I had to drop the whole enchilada. Stuck? Yeah....that's the word.
It's out now. Pics to follow after yard duties.
Sun, Jul 22, 2012 3:36 AM
