D2 draw bar not big enough
Showing 1 to 10 of 12 results
Claremontcat
Send a private message to Claremontcat
Just got an old log arch to go with my D2, attachment part is 3 inches thick and the draw bar can only take 2 inches. Thinking replace draw bar with one from bigger Cat, or have someone cut and weld mine to take 3 inch attachment.  What would you do?
Mon, Jul 25, 2022 5:08 AM
Thank you received: 140
Hi, Claremontcat.
Buy a bigger Cat. After all, how many is too many??????????????????????
I think I'd go with the cut-n-weld option. If'n yer worried about appearances, try to make it look as much like the original as possible
Mon, Jul 25, 2022 5:18 AM
Thank you received: 62
From pictures looks easy to change the clevis on the log arch. If you don't loose the old clevis you can always go back if you wish.
Undue the big square headed bolt. Build a new clevis.
Mon, Jul 25, 2022 5:22 AM
This is what Hyster made for towing the arches.
[attachment=68453]Hyster Hitch #2 001.jpg[/attachment] [attachment=68453]Hyster Hitch #2 001.jpg[/attachment] I would make a smaller hitch on the arch, Hyster made a special hitch for towing sulky's[attachment=68450]Hyster Hitch 001.jpg[/attachment]
Mon, Jul 25, 2022 6:03 AM
Claremontcat
My first thought was attack the log arch clevis, but the U shaped bar that holds it is also 3 in thick and if I take 1/2 in off top and bottom so it clears the draw bar it will take about 1/2 the metal around that big bolt that holds the clevis.
Mon, Jul 25, 2022 6:05 AM
Claremontcat
Reply to Claremontcat:
I like the idea of building a hitch just for the log arch - this thing is bigger than the Sulky but I don't plan on pulling heavy loads with it. Thanks for the idea!
Mon, Jul 25, 2022 6:29 AM
Thank you received: 55
here's another idea get some heavy wall rhs and make a pocket that slides over the draw bar and picks up the draw bar pin then using heavy flat bar make a new drawing point that will take the clevis. the pocket will also need plating with flat bar to reinforce it a bit too. oh and be sure to use a grade 8 bolts for draw bar pins so it will have an engineered failure point as a high tensile bolt that is a proper fit will snap rather than bend and thus do less damage.
though hyster had made a hitch mount that picked up bolt holes on the winch body and thus was very strong. so you could make a replica of that too.
Mon, Jul 25, 2022 6:45 AM
Reply to trainzkid88:
as another suggested make a new clevis block. but make it a bit longer so you can step the thickness and have a nice radius to change to the thicker section that would eliminate you not enough meat around the bolt concern. and the radius would prevent stress fracturing
Mon, Jul 25, 2022 6:51 AM
BeGe made pocketed drawbar extensions for the D2/4. Maybe you could modify one of them for you purpose without hacking up the drawbar.
 [attachment=68455]D4 BeGe drawbar extension.jpg[/attachment]
Mon, Jul 25, 2022 7:13 AM
d4angelo
Thank you received: 8
That BeGe pocket drawbar extension is exactly what I need for my D2. My D2 has a belt pulley at the rear that makes hooking up implements difficult. Does anybody have one for sale?
Mon, Jul 25, 2022 10:34 AM
Thank you received: 289
Reply to d4angelo:
[quote="d4angelo post=239505 userid=1377"]That BeGe pocket drawbar extension is exactly what I need for my D2. My D2 has a belt pulley at the rear that makes hooking up implements difficult. Does anybody have one for sale?
***I would have to ponder selling you one with considerable thought. As it would affect my "hoarder" status if I gave up one of mine... I have the BeGe drawbar extensions for D4s, but have never come across one for any other sized tractor. I have never tried to fit one to any of my D2 tractors. I shall test one for fitment.
Caterpillar used to have extensions of their own, but they were simply made of flat plate steel, welded together. In my personal opinion, the cast BeGe ones are much nicer. They are even more unique, as one is able to pin several of them together to add length. I have a set that was a "triple". JM
 [/quote]
Mon, Jul 25, 2022 7:55 PM
