Isn't the P14 just like the P51 just not as many cylinders or am I confused on this?
i have no idea, i am new to this adventure
Hello markr
You ask the year of manufacture of your D 2 - Serial No 3 J 5627, it was built during the 1941 production year. The other number that you quote is I beleive not a CAT number at all
Regards
Alan T.Lewis
Christchurch
NEW ZEALAND
Yes, the P51 Mustang had 12 cylinders and was an Allison engine or a Rolls Royce Merlin. 😆😆
I don't know where you found the 20P number but it could be a part number or casting code. The engine should have the same serial number tag as found on the rear of the transmission. The engine tag should be on the left rear side of the block just below the cylinder head. The block should also have the serial number stamped on the bottom edge just above the oil pan.👍
the number was tagged on the left side of the engine right where you said. I did not look at the block.
Mark
The D2 SERIE 3J should have a 3400 CATERPILLAR motor
is the 3400 a four cyclinder engine?
