D2 dimensions w/ blade
Showing 1 to 10 of 14 results
toolhawk
Send a private message to toolhawk
Ok new to this site , bought this D2 the other day and need to go pick it up , I know the the weight but what are the dimensions , width of machine and blade , just need to figure what trailer to take. Will have lots of questions in the future .Thanks
[attachment=21647]$_57.jpg[/attachment]
Thu, Feb 13, 2014 1:49 AM
4D2Ken
Send a private message to 4D2Ken
Welcome to ACMOC. What model of D2 is this (eg. 4U, 5U)? The surest bet is to have the person you purchased the unit from measure it for you.
Thu, Feb 13, 2014 2:29 AM
Cysco
Reply to 4D2Ken:
toolhawk,
This is the trailer I haul my D2 on....6 ton net rating. I had a 5 ton but it was to close on weight for me.. The blade should be just under or right at 8 foot.
Hope this helps.........Bill
Thu, Feb 13, 2014 5:13 AM
toolhawk
Reply to Cysco:
toolhawk,
very good my trailer will be fine than , 14,000 rating - 2500 lb for wt. of trailer, the pic with d2 on trailer answered my question , not sure of the model , will know next weekend.
Thu, Feb 13, 2014 7:17 AM
Peter C
Send a private message to Peter C
Reply to Cysco:
toolhawk,
[quote="Cysco"]toolhawk,
Hope this helps.........Bill[/quote]
I will be looking for a trailer in the future. Who is the manufacturer of your trailer?
Pete
Thu, Feb 13, 2014 7:24 AM
Cysco
Reply to Peter C:
Pete
[quote="Peter C"]I will be looking for a trailer in the future. Who is the manufacturer of your trailer?
Pete[/quote]
Pete,
The manufacturer is Hudson Bros. Trailers in North Carolina. I picked it up on my way north to get the D2. I have owned several Hudson trailers and have been pleased.
Have a good evening....Bill
Thu, Feb 13, 2014 8:54 AM
Peter C
Reply to Cysco:
Pete[/quote]
Pete,
[quote="Cysco"]Pete,
Have a good evening....Bill[/quote]
Thanks, Bill. I'll look at them. I may be passing through Dahlonega in April if I take my friend to Springer Mountain so she can hike the AT. Hope the storm didn't cause much problem for you.
Pete
Thu, Feb 13, 2014 6:23 PM
Cysco
Reply to Peter C:
Pete
Pete,
I think you would be pleased with Hudson.....They use channel iron instead of bent metal for gross rails. They will also customize as I wanted an open type dovetail versus a wood plank.
Drop a note here if you decide to come through Dahlonega. I recommend staying at the Smith House....you won't be disappointed and it is just off the town square.
Have a good day....Bill
Thu, Feb 13, 2014 8:24 PM
Reply to Cysco:
Pete,
This is my tilt trailer I use for my D2 and smaller equipment---I agree with Bill that a 5 ton is marginal for a D2
[attachment=21659]ibm 224.jpg[/attachment]
BTW---my 4u blade is 67 inches wide
Fri, Feb 14, 2014 2:57 AM
Gregness
Reply to dpendzic:
Nice looking little Cat- I would say a 4U or maybe 5U with electric starter for the Pony. Cool!
G
Fri, Feb 14, 2014 5:42 AM
Thank you received: 63
Reply to Gregness:
G
Cysco, is your trailer the Pro or Advantage series? There's one on feebay needing a fix-up - I could be interested but it's a five ton so I'm not sure it's worth it (I also have a D2 to haul) - at least I think it is because the owner says it's a 10,000# but with two dual tire axles it looks more like a 14k minimum.
Neil.
Fri, Feb 14, 2014 9:38 AM
