D2 Diesel / No fuel pressure / will not start
Showing 1 to 10 of 29 results
D2Malvern
Send a private message to D2Malvern
I am struggling to get any fuel pressure on my D2.
I have fitted new fuel filters and gaskets.
I am hoping the following video may help:
https://youtu.be/T4LVm9CEeYM
[video]https://youtu.be/T4LVm9CEeYM[/video]
It hasn't run for years it had a long period of not starting, probably at least 10 years.
Any pointers most welcome.
3J6425
Mon, Jun 5, 2017 3:04 AM
Thank you received: 61
It's not really a gusher is it? Check your fuel tank valve is fully open. You can disconnect the fuel supply line at the transfer pump and check that you get very good flow for that half inch line - make sure it's sustained good flow. Can you supply a video of you cracking open the main throttle with the compression closed and then loosening off an injection line to see what comes out.
Also, update your profile up there on the right "My Profile" with your city and state - there may be a member close by that can help if it's stubborn and won't start.
(edited my post a couple of times : )
Mon, Jun 5, 2017 4:15 AM
First of all I hate cell phone pics and videos!!
now--have you checked the relief valve on the transfer pump? can crud up and prevent pressure buildup
If you changed the filters are you sure you got the gasket back on correctly--there are holes in it that have to line up with the fuel passages
Mon, Jun 5, 2017 4:51 AM
D2Malvern
I seem to get some flow out of the bleed valve on per filter. Seems very poor on the clean side of the filter. I have to fully unscrew the needle to get any flow.
I have tried cracking open and injection line - very poor flow. Video is uploading..
3J6425
Mon, Jun 5, 2017 4:52 AM
Do you get heavy white smoke when you pull the throttle open? Many times there is enough wear and lost motion in the throttle linkage to prevent the governor setting actually moving until the throttle is close to wide open. Even if the governor lever moves, the rack inside the fuel pump housing may stay in the fuel shutoff position and prevent fuel injection. This is usually the result of a pump plunger sticking up and its lifter not returning to follow the cam lobe. This will be obvious if you take the side cover off the pump housing and watch the motion of the lifters. Usually a spray of the plunger with penetrating oil and prying with a screw driver on the lifter will get one working again and get the rack moving freely left and right with only gentle pressure.
Wouldn't hurt to spray the bushings the rack slides in on the left and right side of the housing, but those tend not to be the problem........usually a stuck plunger instead. If they do not come back down, they also do not twist, so the rack and fuel setting remains where it was when the plunger stuck. This can be at wide open throttle and result in a runaway after starting, so some caution and preplanning is warranted whenever starting an engine that has been sitting a long time. Pulling the decompression lever is usually the fastest way to get it under control if it does take off. Can also shut off air if you have the top off the air breather and a board, book etc handy. Make a plan ahead of time so you do not waste precious seconds.
The most common cause of low pressure is a faulty pressure relief valve located in the inlet adapter block where the fuel line attaches to the transfer pump. Can also have a worn pump, but the pressure relief spring and poppet are a lot cheaper and easier to fix, so I would start there. When you unbolt the inlet adapter, you can turn on the tank valve and check for good flow by gravity through that point in the system. Sometimes you do not even have to disconnect the fuel line, just remove one or more support clips along the base of the block so the inlet block can drop down without bending the line.
Mon, Jun 5, 2017 4:55 AM
D2Malvern
I get very little white smoke when cranking with compression lever set to run and throttle set at 3/4.
Video of opening various bits (if you can manage watching it!)
[video]https://youtu.be/HL-uu3PkwF8[/video]
3J6425
Mon, Jun 5, 2017 5:16 AM
D2Malvern
Reply to D2Malvern:
I'm not sure where the pressure relief valve is on the the lift pump.
I have a parts book photo:
https://drive.google.com/file/d/0BzelDYgfv-KsSmN4U0tOVlZSUnM/view?usp=drivesdk
Edit /Just read above post.
The tractor used to run well, the problem has come around after not being started for a long while.
I am delighted with how well the starter pinion works now - I followed a video guide on you tube by a member of this forum. Really helpful.
3J6425
Mon, Jun 5, 2017 5:18 AM
Thank you received: 31
Reply to D2Malvern:
the upper tower bleed drains via one of the tubes that exit below the tower. They often get blocked by mud daubers.
No flow from the bleed tube can also result from the tower cover and plate gaskets fuel port holes not being orientated correctly.
The flow I saw from the tower bleeds looks about normal for cranking speed.
The flow from the injector pump we could not see but it usually comes out lazily with the rack in the shut off position.
The flow from the injection line is the same when the Rack is in the shut off position and comes out in mainly spurts when the rack is open. Remember also that the fuel spurts for a small D2 engine means little spurts or it would be a fuel hog.
As CCJ says, remove the pump side cover and see if the rack is moving when the shut off/run lever is activated and also moves from Low to Full rack when the speed lever is activated.
If a pump plunger or lifter is stuck do not try and slide the rack to and fro to loosen them, ONLY ever gently prise the lifter up and down to get them to loosen or you run the risk of shifting the quadrant gear on the inj. pump plunger and therefore change the fuel volume injected for that pump--new pump is usually the only fix without a test bench to re-calibrate the unit--even then it is doubtful a worn pump would be re-calibrated to run correctly.
Mon, Jun 5, 2017 6:53 AM
Reply to D2Malvern:
[quote="D2Malvern"]I'm not sure where the pressure relief valve is on the the lift pump.
I am delighted with how well the stairs pinion works now - I followed a video guide on you tube by a member of this forum. Really helpful.[/quote]
Remove the adaptor, pull out the spring and the black plastic "plunger" and there's a steel cap on the other end I think - could be wrong. Spring needs to be in good order. If not, get a used one from your local dismantler, try Cat parts, or contact Florin (you can navigate to the "Parts Search" link on machinerytrader.com and enter your part # and it will tell you who has one. Most times when Florin does not show in the listing, they can get it anyway.
I just searched on your behalf and there's a couple of places in the Americas and one in Oz that have them. You can also find a spring that's close enough from the hardware store that would do for an "emergency" fix. You'll also need a new gasket for the adaptor. You can just make one with some gasket paper from your local auto store. Slap some anti-seize on it and it'll not stick next time.
Mon, Jun 5, 2017 7:06 AM
is your fuel pressure gauge working--if it does what does it read?
Mon, Jun 5, 2017 7:32 AM
gauntjoh
Librarian
Thank you received: 5
Reply to dpendzic:
Hi, There are several cat enthusiasts near Malvern who may be able to help you, pm me for contact details.
Mon, Jun 5, 2017 12:02 PM
