D2 D3400 Compression Release Mechanism Question
Showing 1 to 10 of 11 results
Sasquatch
Thank you received: 5
So the YouTube comments section has raised a good question from my latest video and I don't have any answers to reply back with so I wanted to ask the folks here to see what a good response would be - the question is why did Cat decide to hold the intake valve open to decompress the engine and not the exhaust valve like others did? This is regarding the D3400 in the "J" series D2's but I know Cat also held the intakes open to decompress other engine models as well. So is there any specific reason/benefit in using the intake valve? Or is it just as simple as the old saying that "there's more than one way to skin a cat"?
Sun, Jan 26, 2020 6:07 AM
Good question.
Sun, Jan 26, 2020 6:53 AM
Thank you received: 77
Hi Toby,
a good question,
I once asked that question at The Dealer in early days of working in the engine rebuild shop as an Apprentice and I was told it was because you can have loose soot, water and other crud in the exhaust pipe/manifold.
The exhaust system is basically unfiltered air that water can sometimes get down the pipe too and some of that crud would get drawn into and out of each cylinder via the dirty exhaust system, whereas utilizing the Inlet system the air transferred in and out of the cylinders would essentially be clean.
Or words to that effect.
Sun, Jan 26, 2020 6:55 AM
Reply to edb:
Hi Toby,
a good question,
Thanks edb!
I learned something today!
Sun, Jan 26, 2020 7:53 AM
I think it’s obvious that moving filtered air in and out of the cylinders is preferable to the carbon and other crud that could be in the exhaust system. I’ll grant the point that the efficiency of sucking anything back in from the exhaust would be pretty low, but still possible for chunks to fall into the open valve and get stuck.
Sun, Jan 26, 2020 8:22 AM
Hi Toby,
credit where it is due here, as I thought that Rome K/G had posted just before me (I saw his post after I posted mine above) about the Pony motor exhaust heat being circulated thru the Inlet system to help heat the main engine's combustion chambers etc.--he is correct for later engines fitted with the pony exhaust heater tube thru the Inlet manifold.
Sun, Jan 26, 2020 9:16 AM
Reply to edb:
Hi Toby,
HA! lol yea i thought maybe you guys thought my answer was out in left field!!! lol so i deleted it.
Sun, Jan 26, 2020 9:49 AM
d2gary
Thank you received: 63
I love your left field answers
Sun, Jan 26, 2020 10:02 AM
Sasquatch
Reply to edb:
Hi Toby,
Thanks guys, utilizing the heat generated by the pony exhaust as Rome K/G mentioned had ran through my mind as well, although like edb said this early D3400 I'm working on is one of the first generation units that just dumped the pony exhaust straight out instead of running it through the diesel intake - I always found it strange that they did it that way when you consider the time when this D2 was built they were already utilizing the pony exhaust heat on the bigger models with the upright starting engines. I would've thought that small displacement D3400 would've needed all the help it could get from the pony but it took a little while before they started running the exhaust pipe through the diesel intake on the D2's.
Several viewers questioned whether holding the intake valves open during cranking might cause intake air to be blown back out through the air cleaner, but obviously that has never been an issue. My thoughts on this were that the combination of an engine that has reduced breathing capacity due to being decompressed combined with the fact that as cylinders are coming up pushing air back past their intake valves, there are other cylinders that may be scavenging this displaced air due to their valves also being held open while those pistons are on their way back down creating an easier path for the air to go than back through an oil bath air cleaner?
At any rate, the preference of clean filtered intake air being pushed around over the dirty exhaust source makes perfect sense - I much appreciate the help!
Sun, Jan 26, 2020 10:11 AM
Reply to d2gary:
Thanks Gary!!!
Sun, Jan 26, 2020 10:40 AM
This topic seems the most relevant to my issue, so I'll ask for advice here. I'm new to engine mechanics and I own D47U10608, from which I'm learning some of the D315 basics. My current problem is this: My compression release lever gets stuck in "run mode" (compression engaged) and will not return to "start mode" (compression released). What happens is this: The plunger does not plunge as intended, but rather, it rotates sideways a bit on its spring and locks up under pressure from the cam. When shifting in the opposite direction, from start mode to run mode, the plunger performs exactly as designed, riding smoothly on the cam as the cam presses downward on the plunger. My question is: Can somebody give me a bit of guidance here on how to remedy this problem?
Sat, Sep 12, 2026 4:16 PM
| Kingaroy, Queensland
