D2 coolant temp gauge
Showing 1 to 9 of 9 results
d126cms
Send a private message to d126cms
Hello everyone, I'm needing a new/nos coolant temp gauge for my D2 anyone out there have one. I fear this maybe one of those get in line questions seem to be hard to find
Mon, Jun 7, 2021 10:11 AM
Thank you received: 55
go to the local parts joint and buy a mechanical type gauge you will get the same type of gauge. the cat ones were really a idiot light and only told you is it within range or not.
Mon, Jun 7, 2021 11:39 AM
brewzer
I have one for a 22. Not sure if it is the same as a D2.
Tue, Jun 8, 2021 12:04 PM
d126cms
I’m not certain either If a 22 is the same does anyone know ??
Sat, Jun 26, 2021 10:35 AM
josh
Thank you received: 14
Reply to d126cms:
The temp gauge numbers for the 22 and the J model D2 do interchange.
Sat, Jun 26, 2021 1:07 PM
kittyman1
Reply to josh:
another option just throwing out there for a mechanical coolant gauge is from A+I
-they make all kinds of old tractor parts etc....just bought one for an old Case tractor....reads on the button and inexpensive...$30...
Sat, Jun 26, 2021 2:08 PM
brewzer
Reply to kittyman1:
I have 2 22 temp gauges. Both are used and work good ( I tested them) . The face on one is pretty bad $150 and the other is pretty good. but the bottom is rusted out. $100. I have 2 other gauges that look real good but don't seem to be real accurate . Both have different length cable for pickup. $50 each. The gaugees themselves are exacly the same as the originals. I have 2 other gauges that look real good but don't seem to be real accurate . Both have different length cable for pickup. $50 each. The gauges themselves are exacly the same as the originals.. [attachment=63816]cat gage 1.JPG[/attachment][attachment=63817]cat gage 2.JPG[/attachment][attachment=63818]stork.JPG[/attachment][attachment=63819]SW.JPG[/attachment]
Tue, Jun 29, 2021 1:39 AM
d126cms
Reply to brewzer:
Hey brewzer the bottom black gauge without the operating range is what I need, it seem not to be real accurate is that correct?
Wed, Jul 14, 2021 10:58 AM
brewzer
Reply to d126cms:
Yes, the needle moves but is not accurate.
Wed, Jul 14, 2021 11:48 AM
brewzer
Reply to brewzer:
PM sent.
Thu, Jul 15, 2021 12:22 PM
