D2 Clutch plate thickness spec?
Showing 1 to 10 of 17 results
Dan Pratt
Got the engine out of my 5J so good time to evalute the clutch. I checked my 5J/5U service manual for a plate thickness minimum spec, and it does not appear to have a spec. Book has clearance specs, but none for minimum service thickness.
My question is, what is the spec?
Disk has maybe 0.040" wear on each side by eye ball guess, based on the original tooth thickness.
Thu, Jan 17, 2013 12:06 AM
shovel man
The centre of the clutch plate would be the same thickness as the teeth when new on a 5J,
I have a new one on the shelf if I remember I'll mesure the thickness tommorrow.
shovel man.
Thu, Jan 17, 2013 4:44 AM
Dan Pratt
Reply to shovel man:
shovel man.
Let me clarify I am looking for the thinnest it can be and still be considered usable. The new plate thickness is also measureable at the teeth.
I do not want to replace it if I am still at - say - 50% good.
Thanks!
Thu, Jan 17, 2013 7:34 AM
shovel man
Reply to Dan Pratt:
Thanks!
Well I measured the new clutch plate (4B3450) and it is .375 " thick (3/8 inch) I also have some used plates and my guess is
when they get down to .3 of an inch its time to replace it,
I also have some new clutch brake linnings for a D2 part # 4B3436 they measure .25 inch thickness.
shovel man.
Mon, Jan 21, 2013 3:57 AM
Dan Pratt
shovel man.
I got a good measurement on the thickness of mine. It was 0.300 give or take a thou.
I decided that was too thin too, so I got a good used U model clutch plate, that was at 1/2" thick with really good teeth. I plan on taking it to a buddy with a lathe to true it up first.
Disk cost $100 but since it is thicker than a new J model, It should last another 70 years. 😆
Thanks shovel man!
Mon, Jan 21, 2013 8:19 AM
josh
Thank you received: 5
Reply to Dan Pratt:
Thanks shovel man!
Dan,
The U model clutch plate will not work in a J model due to its thickness, when you have it turned down, you might want to get it pretty close to the new thickness for a J. I measured .388 for a NOS J plate and .680 for the U.
Mon, Jan 21, 2013 10:52 AM
Dan Pratt
Reply to josh:
Dan,
OK thanks Josh.
Mon, Jan 21, 2013 11:45 AM
Thank you received: 21
Reply to Dan Pratt:
OK thanks Josh.
Dan, I had the option of getting a new U-series from General Gear and turning it down but in the end for a few clams more I decided to just get the new J-series one from Cat. It's a two piece, meaning that it has a center component with the engaging teeth made out of a different material than that used for the friction. I want to say each sliver of friction is maybe an eighth of an inch thick, so that would be the absolute maximum it could wear.
Tue, Jan 22, 2013 3:29 AM
Dan Pratt
Well, I bought a used U model disk and had it machined down. Turns out the core and friction surface are different materials. After turning down, all that is left is the structural part, made of some composite fiber like bakelite. Too bad as it had perfect teeth, which is why I selected it.
So, now I have to find another disk either new or for the J model that will work.
Cost me $100 for the used disk that is now unusable. General gear appears to have only one type of disk for all the D2 models. If I buy one, I will likely have to have it machined down. Is CAT the only other source for the J disk? I am afraid to ask what they want for it.
Mon, Feb 18, 2013 1:07 AM
Reply to Dan Pratt:
I ended up buying my J-series plate from Cat. It is also made of a core with friction glued to it. Cost about $200 and is about 4/10" thick. I welded the cracked 5B2519 (that's the plate that you tighten to adjust the clutch) and trued it and the other plate. Clutch is ready to go back together when I get my flywheel back from the machinist with the new ring gear fitted, which I got from General Gear.
Mon, Feb 18, 2013 2:33 AM
sr4440
Send a private message to sr4440
Hi Dan,
I got my new clutch disc for my J from Florin Tractor. I think it was $140.00.
I'll send you a PM with their number if you want.
Scott
Mon, Feb 18, 2013 8:06 PM
