D2 clutch brake
D2 clutch brake
JbinkD2
Send a private message to JbinkD2
My d2 3j needs new friction material for the clutch brake could someone tell me the proper thickness material to get and the best way to rivet it to the metal plate. Thank you.
Fri, Mar 7, 2025 8:18 AM
Busso20
Thank you received: 12
try general gear, they have steering and clutch parts, not sure on there location in the states
Fri, Mar 7, 2025 9:41 AM
d4angelo
Reply to Busso20:
Fri, Mar 7, 2025 12:14 PM
maxdog55
Send a private message to maxdog55
Hi Jbink, Did you find any info on the clutch brake material? I'm in the same boat.
Tue, May 27, 2025 7:36 PM
Thank you received: 24
I'd imagine it's the same material that would be used for the steering brakes, in which case a visit to your local brake shop would be in order. I took the steering brake shoes off my D2 to a local brake shop and he just did what he did without much input from me. He used standard brake material and glued them on
Wed, May 28, 2025 7:07 AM
