D2 Chassis Book
D2 Chassis Book
rockymnt
Send a private message to rockymnt
Would a D2 chassis book show all the torques vales for the final drives and brake drums and clutch packs...
1952 Cat D2
Wed, Mar 15, 2017 9:26 PM
Thank you received: 77
My Form 30441 doesn't show any bolt or nut torques that I could find - just the sprocket pressing-on pressure at 15t, which folks here caution to only use 10t as the sprocket can split (I think I have that right on this tractor). For nuts and bolts, I understand the approach is just to use the standard tightening torque for the fastener size. There is a post on here somewhere that shows the torque for each size. The book does say to heat the steering clutch hub when it is fitted to the shaft and tap it on. The heat will expand it some so it fits tighter when the temps equalize.
Wed, Mar 15, 2017 10:50 PM
rockymnt
Thanks Neil,
What does the chassis book have in it, any usable information ?
1952 Cat D2
Thu, Mar 16, 2017 12:04 AM
Reply to rockymnt:
Thanks Neil,
It's the serviceman's reference book, so it provides procedure for dis/assembly. You can find one on eBay frequently - usually go for 30-50 clams. There's also the parts catalog, which is self-explanatory, and the operator's manual too. If you get all three that cover your serial #, those, combined with the accumulated knowledge here on the forum will enable you to fix anything on that tractor.
This should get you started: http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.Xcaterpillar+d2+serviceman%27s+reference+book.TRS0&_nkw=caterpillar+d2+serviceman%27s+reference+book&_sacat=0
and this: http://www.acmoc.org/bb/showthread.php?27180-Manuals-etc-for-sale
Item #9
Thu, Mar 16, 2017 6:05 AM
Item #9
In an older thread is the info you are asking for???
Clutch Packs, Brake Drums and Sprockets........
Try the SEARCH function in the upper right corner of your screen
Thu, Mar 16, 2017 7:36 AM
