D2 cat pulling to the left
Showing 1 to 10 of 12 results
nhra6284
Send a private message to nhra6284
Ok, so I finally got the D2 I have been working on to run decent. Now, it pulls to the left when going down the driveway. Gets worse the more load you put on it (grading gravel). Both side brakes and clutches work just fine. The only thing I can see is the right track is tighter than the left. Would that make this thing pull to one side?
Wed, Nov 13, 2019 2:40 AM
JackD6-5R
My D-2 Pulls to one side, but the one track is worn more than the other. Tracks from2 different machines.
Wed, Nov 13, 2019 2:56 AM
STEPHEN
Reply to JackD6-5R:
Left clutches could be slipping. I guess you know that the steering lever needs some free play to account for future wear?
Wed, Nov 13, 2019 5:28 AM
Duane
Send a private message to Duane
Reply to STEPHEN:
My uncle bought a D4 in the 1970s brand new. It has been mostly used for dozing in decent conditions, good farm dirt, not much rock.
As long as I can remember, it has always traveled off to one direction when roading. Traveling down the dirt and gravel roads, I would get the scheme worked out to aim at the far side of the road at some not too distant point, and it would never leave the road. It would travel in a big arc, and then I would aim at the far side again. Very annoying. When working it as a dozer, no obvious problem. Pulling farm equipment, or grooming roads, there might be an issue. No slipping clutches, and as I recall I could never detect any obvious wear differences, all original undercarriage, never any major work done on the tractor. I would say it is still a low hour, low use, good condition machine. I wouldn't mind owing it.
Next time I get close to it, or run it, I will be looking again, i'm sure.
Your problem does sound like possible steering clutch slippage if it gets worse with increased load.
Thu, Nov 14, 2019 2:45 PM
Thank you received: 22
Reply to Duane:
As well as relative track length, track roller frame alignment could play a part, even in a brand new tractor. Eddie B has some diagrams about track frame alignment. I thought I had saved them but can't find them. But basically, the frames should be parallel, perpendicular to the pivot shaft, the rollers, idlers and sprockets should all be in line, the track frames should be straight in both planes and not twisted, spaced the same width out from the tractor body, etc., etc. My D2 is all over the map so part of the r-n-r is to remove the wear and get the alignment right
Thu, Nov 14, 2019 8:34 PM
tom
Send a private message to tom
Watch from the front when someone else is driving. See if the grousers slide one way or the other as the machine moves forward. Could indicate an alignment issue.
Fri, Nov 15, 2019 12:21 AM
Duane
That all makes sense, and brings up some things I had not thought of.
Thanks!
Fri, Nov 15, 2019 10:14 AM
catskinner
Reply to Duane:
Thanks!
Yes, a too tight track on one side will make a difference in going in a straight line. catskinner
Sun, Nov 17, 2019 10:59 AM
Reply to catskinner:
data as mentioned.
Sun, Nov 17, 2019 11:07 AM
Reply to edb:
data as mentioned.
Thanks for posting that Eddie, much appreciated!
Mon, Nov 18, 2019 7:37 PM
npalen
Send a private message to npalen
We had a D2 and an RD6 on the farm back in the fifties with both used for moldboard plowing. The RD6 ran on land but the D2 ran the right track down in the furrow pulling its 3-16 plow. This wore the rail unevenly and driving it down the road was constantly steering it in a straight line.
Sun, Jan 12, 2020 12:31 PM
