D2 Cat adjustable fan belt pulley
Showing 1 to 10 of 13 results
davidbrodhead
Send a private message to davidbrodhead
I want to tighten up my fan belt a little.The locking bolt comes out OK,but getting the threaded side of the adjustable pulley to move isn't happening. Hard to get ahold of anything in there.I've squirted some rust penetrator on the threads.Anybody got any tricks?
Tue, Aug 18, 2009 11:51 PM
Thank you received: 19
A lot of folks adjust them with a punch......and proceed to bugger up the clamping feature. The only trick I know is to remove the two clamping bolts which have a relief drilled hole that will accept an adjustable pin type spanner wrench.
Wed, Aug 19, 2009 12:08 AM
davidbrodhead
I agree that taking a punch to the threaded hole for the locking bolt will wreck the threads for the locking bolt.Where are the 2 clamping bolts you mention? Are they bolts holding the fan to the water pump?This is a running motor with all in place such as radiator,fan,existing fan belt,etc.Do you need to get the hood off to gain some access? This is a 5j7822 by the way.
Wed, Aug 19, 2009 1:02 AM
Reply to davidbrodhead:
If you only have the single locking bolt on the fan side the spanner will not work. The two lock tab version is the one that will accommodate the pin spanner.
Wed, Aug 19, 2009 3:14 AM
davidbrodhead
Mine is the single locking bolt type.Any other ideas?
Wed, Aug 19, 2009 3:28 AM
chriscokid
let it soak in PB blaster over nite then take a brass rod or punch and work it back and forth to loosen the pulley half. Some times a large pipe wrench may be needed if the other does not work. A little elbow grease goes a long way.
Wed, Aug 19, 2009 4:10 AM
timbo1946
Send a private message to timbo1946
Reply to chriscokid:
I have used a strap wrench after letting soak. Doesn't always work, but better then braking the pulley right off the bat. Tim
Wed, Aug 19, 2009 4:59 AM
Reply to timbo1946:
Go easy.....the pulley is easy to break.....and there are no new replacements.
Best you can do is soak until you can get it to move....tapping or otherwise...then spend plenty of time working it back and forth with periods of soaking until you can get full thread turning. If/when you get it loose and free, coat the threads with never seize.
Wed, Aug 19, 2009 6:55 AM
bcwayne
Reply to timbo1946:
I've been successful placing the tip of a flat blade screwdriver in the notch of the adjusting ring, and the handle on a protrusion on the block, then grab the fan and turn..... one side of the block to loosen, the other side to tighten.
Wed, Aug 19, 2009 7:00 AM
Reply to bcwayne:
I use a similar technique, just usually not a screwdriver, but anything that you can jam between one of the webs on the rear of the pulley and something else that will not move. You want to make sure whatever you use gets a good rest on the pulley so you don't chip it or have the bar or whatever get too crosswise and push the pulley forward instead of around if that makes sense.
I have also used a bit of heat with a torch on one that wouldn't break free and I didn't have time to soak. Your bearings are regreasable and unless you go crazy with the torch, you can usually get it to loosen right up long before it gets too hot for the seals and bearings. The belt is against the hot part, so you might want to keep it dampened with water while heating if you have to get it real hot.
Wed, Aug 19, 2009 9:23 AM
davidbrodhead
Good news for me.The pulley is no longer seized.I had squirted some rust penetrant [brand unknown ] on the threads a couple of days ago.I had no luck breaking it free after letting it soak for a day.Last nite I put KROIL PENETRANT [probably similar to PB BLASTER } on the threads.I followed the instructions and waited a few minutes.I then grabbed the adjustable pulley with a large channel lock plier with one hand , held a fan blade with the other hand,and pulley broke free.Hard to tell if the original penetrant or the KROIL loosened things up,but I'm giving KROIL credit for now.No drift pins or heat necessary for this pulley this time.THANKS FOR ALL YOUR HELPFUL RESPONSES!!!
Wed, Aug 19, 2009 10:58 PM
Earlcoate Charity Open Day
