D2 5Uxxxx pony engine connecting rod dimensions
Larry
Send a private message to Larry
Anyone out there have the conn rod dimensions for the big end for the pup engine? I have two rods that need the big end resized, This might be up your alley Old Magnet. I have a sheet from July 16, 1951 but it does not give the sizes of the conn rod. Thanks in advance, Larry.
Fri, May 3, 2013 10:11 AM
According to my old Federal Mogul bearing book if the rod forging number is 7B4524 the large end steel bore is 1.844 in.
Also recommends a high crush pressure.....whatever that is.
Fri, May 3, 2013 10:06 PM
Larry
Old Magnet, many thanks for the info, I will pass it on to the chap finish honing them.
Sat, May 4, 2013 8:16 AM
