D2 5U13205 clutch sliding collar
donald79
Send a private message to donald79
Hello, any info on modifying the 4B3504 sliding collar to machine/drill a cup area and hole to get oil to the shaft? Thanks Don
Mon, Dec 15, 2025 7:19 PM
josh
Thank you received: 10
4B3504 is the bottom half of collar assembly 4B3405, the top half should already be drilled for oil to be received from the oil cup assembly, look at the diagram of the clutch assembly in the parts book.
Wed, Dec 17, 2025 2:52 AM
