D2 5U Wet Clutch and Transmission
jk
Send a private message to jk
Hi. What are the recommended oils for a late model D25U
1) The wet Clutch on machine
2) Transmission on the tractor
3) Final drives
Also does anyone have the section of manual or some images from the manual on how much to fill the OIL clutch or how to adjust it ?
John
Mon, Jan 27, 2025 1:49 AM
jk
Trying to get it working again..
Mon, Jan 27, 2025 2:23 AM
gemdozer
Thank you received: 25
Reply to jk:
The oil master cluch use the same oil than the motor and transmission and final drive use 80\90 gear oil
Mon, Jan 27, 2025 3:13 AM
jk
Reply to gemdozer:
Thank You !
Greatly appreciated.
Mon, Jan 27, 2025 3:50 AM
josh
Thank you received: 14
Here are the instructions for the D2 oil clutch, it does not take much oil, maybe a couple quarts, I can't find the exact amount right now, use the dipstick.
Mon, Jan 27, 2025 10:28 AM
jk
Reply to josh:
Thanks for the information. Will keep everyone posted on the progress...
Mon, Jan 27, 2025 7:37 PM
