D2 5U Water Pump Question
Showing 1 to 10 of 21 results
AnthonyF
Hey all, hoping someone has some insight for me. My D2, serial 5U 17116, needs the water pump seal replaced as it's leaking. I do not have a copy of the service book and it appears none is on the forum Library either. I have a copy of the D4 7U service manual and it says you can remove the water pump without pulling the radiator, but looking at my D2 it appears the water pump has a long stud that would necessitate pulling the radiator to pull the pump forward off that stud? Am I on the right track there, as I do not really want to pull the radiator off if it's not necessary.
Thanks - Anthony
Thu, Apr 24, 2025 3:00 AM
gemdozer
Thank you received: 25
The earlier d2 you had to removed the radiator for remove the water pump but no need the later one
Thu, Apr 24, 2025 11:14 AM
Thank you received: 62
Cat engineers in that era did not believe in giving any more room than was needed. In many cases less than an 1/8 of an inch of clearance. The Service Mans Reference book also expects a level of knowledge that many of us are struggling to gain. Not having a D2 or working on one I cannot say how clear the book might be, on the small details.
Thu, Apr 24, 2025 4:58 PM
AnthonyF
Well for anyone who’s interested I got the water pump pulled off last night in about 45 mins. I had to pull and unthread the unreasonably long stud, thread the pulley completely closed and I was able to get just enough room to slide it out the right side.
Sun, Apr 27, 2025 2:39 AM
GrantJ
Thank you received: 13
I have a late model 5U and it took 3 tries from Florin Tractor to get the proper seal. You might just go straight to Caterpillar for the part. The parts manual was not real clear.
Sun, Apr 27, 2025 2:50 AM
GrantJ
A question??? I see an alternator on your 5U. Is that an available aftermarket kit or did you have to piece it together?
Sun, Apr 27, 2025 2:52 AM
AnthonyF
The alternator was already on the tractor. I have seen lots of different ways to mount an alternator, but these are by far the cleanest and most factory looking. Unfortunately, I do not know who made the casting originally.
Sun, Apr 27, 2025 1:57 PM
Potato Wilson
Thank you received: 26
Howdy if you’re still out there… How did the pump re-build go? I just ordered new seals & gaskets for my 5U as it’s leaking too.
Fri, Nov 14, 2025 3:14 AM
Thank you received: 289
"Tater Dubya: I did mine once (can't find the schematic in my phone) it was not difficult. D4Angelo I believe as well. Neither of us are mechanics, so that says something. JM
Fri, Nov 14, 2025 3:10 PM
d4angelo
Thank you received: 8
JuiceMan is correct. I rebuilt the water pump on my D2 5U but i did it when i replaced the radiator core. I did change the 2 locking bolts that keeps the fan adjustment in place to grade 8 because they like to break off!
Fri, Nov 14, 2025 9:50 PM
Ang: That is interesting. I have not encountered any fan hubs breaking the 1/4" bolts for the lock tabs if that is what you are referring to. Most everything I do here, the bolt bin is mostly grade 8 anyways. JM
Sat, Nov 15, 2025 12:47 AM
