d2 5u tracks
d2 5u tracks
Showing 1 to 6 of 6 results
mp3953
Send a private message to mp3953
So i have a 5u with worn tracks. Machine runs well and I use it but the bushings are worn through and pins exposed. The sprockets have been changed and are not bad as well as some of rollers. My question is can the tracks be repaired and what kind of price. I am just curious if parts are available or if I would have to try to find used ones. Thanks
Sat, Aug 4, 2018 9:54 AM
STEPHEN
How many hours are you going to put on it? The cheapest option would be to find a parts machine with better tracks. Use the track and part the rest.
Sat, Aug 4, 2018 11:23 AM
caterpillar13
Reply to STEPHEN:
how much rail height do you have ?
I had a local shop press new pins and bushings in mine about 20 years ago for about 600.00 dollars
Sat, Aug 4, 2018 11:51 AM
My understanding is that usually a track shop (if there is one in your area still) would not attempt to replace the pins and bushings once the bushings are worn too thin or cracking up. There are tremendous forces involved in disassembling the track components and sudden failure of the worn bushings under pressure is dangerous. Someone may know more about it than me and I would appreciate being corrected if I am wrong.
On the other hand, I could see how someone who had more time than money and had the right shop equipment could disassemble the tracks in a more time consuming but safer way. Then the links could be delivered to a shop where they could be reassembled using new bushings and pins.
The big question is how much meat is left on the rails and how much time and money do you want to spend on it. For that matter the rails can even be built up with weld. I am not sure you could value your time at anything much more than zero and buy the welding rods/wire etc and still come out ahead on rebuilding a set of rails.
Thread discussing NEW tracks
http://www.acmoc.org/bb/showthread.php?25339-New-D2-track-chains
Sat, Aug 4, 2018 11:33 PM
janmeermans
I don't own a D2 and know little about them, BUT, I did have a discussion with a knowledgeable gentleman (who is restoring the first D2 ever built) who went into a lot of detail on how to use chains off of a D3. I can't remember his "handle" when he posts here so I can't give it. Lots of folks here will know of whom I speak. I will be contacting his again for a friend who also needs tracks for his 3j so will get the details pinned down better at that time.
JanM
Sun, Aug 5, 2018 12:36 AM
EL300B
Send a private message to EL300B
Reply to janmeermans:
JanM
I was also told by a track shop that they won't touch tracks with bushings broken or wore through.
Sun, Aug 5, 2018 7:49 AM
Thank you received: 77
Reply to EL300B:
My plan is to use D3 rollers and carrier rollers on my 5U (and probably 3J too). I can't be bothered with fixing up old D2 rollers - time is in less supply than money.
Sun, Aug 5, 2018 9:10 AM
