D2 5U track adjusters?
Showing 1 to 6 of 6 results
Diamond-Ranch
Send a private message to Diamond-Ranch
Hi I have a 55 D2 5U in need of a couple track adjusters mine are ate up with rust, still working but in bad shape, would anyone have a couple? Mine are 1 1/4-7 thread.
Thanks Larry
Mon, Jul 13, 2009 6:27 AM
n7gxz
Send a private message to n7gxz
When I changed my I went to Tacoma Screw and they were able to order a couple of special order ones for me.
http://www.tacomascrew.com/
Kevin
D2 5U13247 Direct electric start, #44hyd, 2S blade, Hyster D2N
Mon, Jul 13, 2009 6:52 AM
ol Grump
Reply to n7gxz:
Kevin
Larry,
If it's the bolts you need, a length of grade 8 all thread will work nicely but remember to set the spring length according to the book. If it's the nuts you need (and can't get the originals retapped) you may have to make your own.
Mon, Jul 13, 2009 7:36 PM
Reply to ol Grump:
Larry,
I had no problem finding 1 1/4" 7 nuts which i used as a backup to the adjuster nut---i tapped the adjuster nut and recut the slots so it would tighten to the bolt threads
Mon, Jul 13, 2009 8:17 PM
JasonPayneCrawlers
Reply to dpendzic:
I have a few😊
Tue, Jul 14, 2009 8:00 AM
Diamond-Ranch
Reply to JasonPayneCrawlers:
I have a few😊
So Jason whats the chances of getting a couple from you? How much do you want for them? I thought of having a couple machined but never persued it.
Thanks Larry
Tue, Jul 14, 2009 8:42 AM
JasonPayneCrawlers
Reply to Diamond-Ranch:
Thanks Larry
Larry I sent you a pm
Tue, Jul 14, 2009 9:57 AM
