D2 5U Throttle friction adjustment question
Oldrnu
Send a private message to Oldrnu
Is there some way to adjust the tension on the main motor governor? Mine is very light and the throttle keeps slowly closing down. I looked in the manuals and it talked about replacing parts in the governor but I couldn't find anything on adjustments. The way I have gotten around this is to bend the actuator rod slightly where it goes through the firewall so that the friction between the rod and firewall keeps the throttle open but wondered if there is a correct way to fix this.
Tue, Apr 18, 2017 9:09 PM
d2gary
I don't know anything about the insides of the magic box but I had same thing happening on my d2 and had to replace the spring in the throttle handle. Holds its position good now
Tue, Apr 18, 2017 9:25 PM
Reply to d2gary:
I added an extra spring on the linkage on mine
Wed, Apr 19, 2017 1:28 AM
Reply to dpendzic:
I rebush the clevis ends on the linkage and replace the clevis pin with a bolt with correct shank length and shortened thread to where I can put the required pinch on the joints. A lot cheaper and more feasible than replacing the ratchet components in the governor. I also fixed one by rotating the ratchet ring in the governor control to a less worn area which also works after removing dowel pins.
Wed, Apr 19, 2017 3:32 AM
Oldrnu
Now that sounds like the "Farmer fix" I was looking for.
Thu, Apr 20, 2017 12:20 AM
