D2 5U Steering lever adjustment
jwwskymaster
Send a private message to jwwskymaster
I am wondering out to adjust the set screws on the steering levers on a 5U series D2.  The service manual I have only talks about adjusting the steering clutch free play by adjusting the squared bolts that are held by a locking clamp.  Nothing about adjusting the acorn nut, or the set screw.
Can anyone help me on this?
Sun, May 26, 2024 7:59 PM
clayton
Thank you received: 25
If you’re a member all info you need is in the technical library just type in D2 and all the manuals are there.
Sun, May 26, 2024 8:31 PM
seiscat
Reply to clayton:
The Operation and Maintenance Instructions(OMI)  is the manual you need. We have a good one in the library. You have to be a paying member($44/yr.) to access it.
I found one on eBay for $69.99+tax
https://www.ebay.com/itm/333189770792
Craig
Sun, May 26, 2024 9:56 PM
