D2 5U Restoration
D2 5U Restoration
Showing 1 to 10 of 10 results
louislindsey72
Send a private message to louislindsey72
This is a build thread for my 1949 D2 5U, #2939. The tractor is going to be restored and entered in the 2016 Delo Tractor Restoration Competition. I'm incredibly stoked about this project, the tractor seems to be all there. The tracks are free, but just about everything else is froze up; pony motor, compression release , pony clutch and engagement levers, hand clutch, shifting lever, and the right steering clutch. I haven't checked the main engine yet, I was going to try putting it in gear as we winched it onto the trailer, but I couldn't get it in gear. I tried putting oil in the cylinders of the pony but that didn't help. I'd assume the next step to to take off the pony motor and rebuild it. Does anyone know what parts are available for rebuilding the pony? pictures of this process? Id like to see what I'm getting into before I tear into it.
[img]http://i429.photobucket.com/albums/qq18/Louis_Lindsey/Mobile%20Uploads/image_zps1rm9dmpa.jpg[/img]
[img]http://i429.photobucket.com/albums/qq18/Louis_Lindsey/IMG_7215_zpsksjmnvbo.jpg[/img]
[img]http://i429.photobucket.com/albums/qq18/Louis_Lindsey/Mobile%20Uploads/image_zpskrwxaitf.jpg[/img]
[img]http://i429.photobucket.com/albums/qq18/Louis_Lindsey/Mobile%20Uploads/image_zpspk4pcdmo.jpg[/img]
[img]http://i429.photobucket.com/albums/qq18/Louis_Lindsey/Mobile%20Uploads/image_zps269jmr92.jpg[/img]
[img]http://i429.photobucket.com/albums/qq18/Louis_Lindsey/IMG_7253_zpsgwg1b9hy.jpg[/img]
[img]http://i429.photobucket.com/albums/qq18/Louis_Lindsey/IMG_7351_zpsdobtj858.jpg[/img]
[img]http://i429.photobucket.com/albums/qq18/Louis_Lindsey/IMG_7411%202_zpssgpwxo6p.jpg[/img]
[img]http://i429.photobucket.com/albums/qq18/Louis_Lindsey/IMG_7409_zpsbuzzi4cv.jpg[/img]
Fri, May 8, 2015 3:20 AM
Mike Meyer
Thank you received: 5
That is a nice D2 to restore as it looks complete, it will be good to watch your progress, I restored a D2 5U about 2 years ago and hopefully it will be coming home in August as it is still 2,000 miles north of me, they are a nice tractor to drive.
Before you pull that pilot motor off I suggest you remove both cylinder heads first to check the bores and valves, it only takes a few minutes and you can reuse the head gaskets 90% of the time if you are careful, you might find a few hours soaking the pistons with a good loose juice like 50% Diesel mixed with 50% ATF, then a gentle tap on the pistons with a block of wood may be all it takes to free the pilot motor, you will have lots to do as it is and hearing at least one motor running will be a confidence booster. Grab the pilot motor flywheel and try and move it, if it moves more than 1/4" in any direction then you may need to pull the motor apart to replace the crankshaft bearings, but if the movement is minimal I'd replace the crankcase oil and work towards trying to fire up the pony unless you have been told by the previous owner it has major internal problems. Get hold of a D2 Owners book ASAP as it will show all the lube points, before firing the pilot motor up you will need to make sure you have oil or ATF in the pilot motor starter clutch / pinion.
If you do a search through old posts on D2 / D4 pilot motors you will find every topic covered that might affect you, basically if the pistons move in those motors and you have a good magneto, clean fuel and a clean carby they will run even on very low compression, you might find that tractor frees up easily with a good soak of loose juice, try the easy way first before taking parts off is my advice.
Good luck
Mike
Fri, May 8, 2015 5:45 AM
mrsmackpaul
Reply to Mike Meyer:
Good luck
Mike
You have a nice complete looking tractor there which is always a good start nice wide grousers or pads as you fellas call them
Mike Im trying my best to get organised for August but it was on the news the other night we have had the driest wet season on record it will most likely be a bit late as I cant be away from the farm to long I gotta stay around and water it will do my best though
seeya
Paul
Fri, May 8, 2015 6:37 AM
Mike Meyer
Reply to mrsmackpaul:
seeya
Paul
[quote="mrsmackpaul"]You have a nice complete looking tractor there which is always a good start nice wide grousers or pads as you fellas call them
seeya
Paul[/quote]
OK Paul, see how you get on, I appreciate you having a go, I was talking to my mate Joe at Innisfail 2 weeks ago and he said it had been dry there, on top of that he said cane prices were down too, so this season will be tough, I'm not sure if I'll get up there to help him plant this year, just have to wait and see, we talked about turning some pins and bushes in old chains I have here. Just looking at some photo's I took of Joe and his fancy hill country planter, it has a Cat 3208 engine running on D7 undercarriage, I realized it was 3 years ago he and I worked on that D2 and it has been sitting in his shed ever since, he fires her up every 6-8 weeks, the pilot motor starts second pull every time.
Regards
Mike
Fri, May 8, 2015 9:52 AM
mrsmackpaul
Mike thanks for the pictures of the planter and the D2 we will get there one day just the stars all have to align fir things to happen and they didnt even get close this year we had about 12 inches of the 40 plus we were meant get of rain
Paul
Sat, May 9, 2015 3:11 AM
Mike Meyer
Paul
That's OK Paul, don't worry, luckily Joe likes having that D2 in his shed even though he has no room for it, you were hoping to take your Mack to Alice Springs weren't you to the Trucking Hall of Fame get together, that will be a big disappointment for you, no doubt your mates in Kerang were looking forward to seeing you again too.
Hi Pete, yes, a picture does say a thousand words, doing the steering clutches in a D2 is more than a few days work because you find other issues as you go that need attention like having to replace all the bearings on the cross shaft and final drives too, plus a broken track spring needed replacing and the brake linings, I learn't some new tricks and some new words working alongside Joe, he has done a lot of these D2 repairs over the years and was fitting a electric starter to a D2 3J while we worked on my 5U, plus we refurbed the track frames on a D6 8U as we went, the guy is a legend, best Bush Mechanic in north Queensland.
I don't want to hijack this thread but the photo's will show it is definitely not a 2 day job and hence I speak from experience when I say to keep it simple initially when working on any old non running Cat.
Regards
Mike
Sat, May 9, 2015 4:05 AM
old-iron-habit
Regards
Mike
Great pictures Mike,
Joe's the guy that works barefoot right. I remember the post from a couple years ago.
Roger
Sat, May 9, 2015 4:28 AM
Mike Meyer
Reply to old-iron-habit:
Roger
[quote="old-iron-habit"]Great pictures Mike,
Roger[/quote]
Yes Roger, that's Joe, only wears boots in the winter time and only for the first few hours of the day till the sun comes up, he's about 73 or 74 years old and still working 7 days a week, 6.30am till 6pm, goes to Church Saturday night because he hasn't time on Sunday morning like other folks, he's a self taught Mechanic who left school at 14 to work on his family sugar cane farm, from May till November he contract plants sugar cane on all the hilly properties, Dec through April he repairs machines no matter what the brand and contracts with his D7 and D8, cutting in new roads, clearing rain forest regrowth, old banana plantations or woodlots, anything that needs doing.
Regards
Mike
Sat, May 9, 2015 4:41 AM
louislindsey72
Thanks for the good advice, I removed the heads on the pilot motor (like Mike suggested) and found that the one cylinder that had the exhaust valve open was full of rust and the wall seems pretty badly pitted. I made an attempt at freeing the piston with ATF and diesel, but the piston wouldn't budge. I even had my brother pull on the fly wheel while I smacked the piston with a block of wood and a mallet. Im out of ideas so now I'm assuming I have to take the pilot motor off of the tractor to free the piston and rebuild the motor. I searched the forums, I may not be looking for the right thing, but is there a specific way of removing the pilot motor? It doesn't look like it can go straight up with out hitting the compression release...
-Louis
Oh and what type of mag did these pilot motors have originally?
Sun, May 10, 2015 4:43 PM
Reply to louislindsey72:
-Louis
First you have to take the dash off. Then there are 8(?) nuts holding it down to the main. Some are way under the cylinders, a couple require extensions and swivel as they are between the pony and main. Compression Release linkage will probably need to be partially disassembled. When it is free, it will lift and tip slightly back as you lift it. Search for Uncle Rich thread as he documented lots of a U series disassembly, his thread makes for good reading!
Sun, May 10, 2015 7:08 PM
STEPHEN
Reply to drujinin:
Original mag would have been an American Bosch, a very good mag. You could stick with the Wico as parts are somewhat easier to get, and being smaller seem to be easier to fit.
Sun, May 10, 2015 7:46 PM
