D2 5U precup
D2 5U precup
Showing 1 to 6 of 6 results
rotorbob
Send a private message to rotorbob
I have a D2 5u105xx that needs a new precup. are there any after market ones for sale or do i need to go to cat for this. pony motor start. thanks Bob
Thu, Dec 9, 2010 11:38 AM
Mike Walsh
Give Mike or James a call. Cat should have an aftermarket precup made in Italy in their "Classic" line for about $25. Not worth your time to order one from another source given free shipping from Hayward. Rain must have you grounded.
Thu, Dec 9, 2010 12:38 PM
Reply to Mike Walsh:
Be interested to hear if you can find them. Last I knew none were available but you can utilize the D4 precup if you rethread the nose down from 1-1/8"- 12tpi to
1" - 12 tpi.
Whooops, coffee hasen't kicked in yet.
That applies to the glow plug chambers....standard chambers are still available.
Thu, Dec 9, 2010 11:20 PM
Mike Walsh
1" - 12 tpi.
Bob. If I am wrong about the availability of a Cat Classic precup, check out Costex Tractor Parts. http://www.costex.com/Library/inserts/O-Z/CTPPB087.pdf I am pretty sure I remember seeing several CTP resellers selling precups for your tractor last year.
My D2 book is at the shop so I don't know what part number you are looking for; let me know if Classic or Costex doesn't work. Regal or American Crane may have another source.
Fri, Dec 10, 2010 6:16 AM
rotorbob
Thanks for the help, I will do some looking. Mike it is slow this time of year,things pick up when the weeds start to come up. Gives me time to work on a cat or two.
Fri, Dec 10, 2010 11:12 PM
Mike Meyer
Reply to rotorbob:
I'm 90% certain I got my new cups and rubber "o" rings for my D2 4U this year from Florin Tractor in Sacramento, I'm 100% certain that's where I got the steel "retainers" that cover those precombustion chambers as mine were almost rusted through.
regards
Mike
Sat, Dec 11, 2010 2:56 AM
rotorbob
Reply to Mike Meyer:
regards
Mike
Thanks Mike for the info. Bob
Sun, Dec 12, 2010 8:35 AM
