D2 5U Pony Motor crankshaft part number?
Kiwicat
Send a private message to Kiwicat
Hi, is anyone able to tell me what the Cat part number is for a D2 pony motor crankshaft, machine serial number 5U5996? Thank you.
Fri, Mar 4, 2016 4:07 AM
gemdozer
Online
Thank you received: 12
The D2 poney crankshaft # is 4b903
Fri, Mar 4, 2016 4:25 AM
Kiwicat
Reply to gemdozer:
Great, thank you. Now I just need to find one...
Fri, Mar 4, 2016 5:25 AM
Thank you received: 23
Reply to Kiwicat:
There are still a few old D2s in NZ but your next closest source might be Oz. Try the wreckers but also look that part # up on machinerytrader.com. They have international listings. "Worse" case you can always get one from here in the US where there are plenty. You could probably get a whole running pony here as your easiest solution. Mike Meyer on here is familiar with periodic shipments of parts from the US to Oz so you might be able to get on that.
Where in NZ are you?
Fri, Mar 4, 2016 5:58 PM
Mike Meyer
I'd be amazed if there wasn't a dozen unused pilot motors laying around NZ but you have to find them, a advert in Trade Me or a trucking / tractor magazine would help, and contact Hudson Biggs, he might know of something.
I have 4 or 5 pilot motor crankshafts sitting in Oregon but I don't know their condition, I mean they looked nice to me but I didn't measure them or have I had them crack tested so it is too risky to start shipping one to NZ as a lot of pilot motor cranks are cracked. I was told last year Tilly's in Queensland were asking $A900 ($US650) for a good crank which is crazy when you can buy the whole tractor for about double that!
Keep asking on here Kiwicat and get a advert into the next ACMOC magazine as a priority, the magazine is seen and read by all 2,900 ACMOC members, this Bulletin Board is seen by only a few hundred.
Good luck
Mike
Sat, Mar 5, 2016 2:43 AM
ronm
Reply to Mike Meyer:
Good luck
Mike
Keep an eye on ebay, you just missed one about a week ago, went for $300...
I have one, but it was already ground .030, & one rod was screwed up again, so no go...I bought a whole engine for $600, needed the crank, a rod, piston, & the block anyway. Had to have that crank ground, as it had been built up & the buildup was flaking off of the mains.
Cranks ain't exactly growing on trees, even here.
Sat, Mar 5, 2016 5:05 AM
rax200
Reply to ronm:
Hi ronm, i agree with you most of the cranks are now been ground to 30 thou or at the end of there life, as i suggest before this would be a good item that the club could get them reproduced and sell the in the store.
Regards
Sat, Mar 5, 2016 5:57 AM
Uncle Rich
Send a private message to Uncle Rich
Reply to rax200:
Regards
Good luck finding a crankshaft. They are out there. Most of the cranks fail for the same reasons. It's not usually the rods but the mains that fail due to the locating pins failing and other lubrication issues. If you are past .030 inch under, you can have bearings made to fit. I am fortunate enough to have the resources to build my own. Check out the fun at this post .
http://www.acmoc.org/bb/showthread.php?17425-D2-pony-crankshaft-thrust-bearings
Sat, Mar 5, 2016 10:15 PM
ronm
Reply to Uncle Rich:
Hey Rich,
Thanks for linking to your thread, I couldn't find it with this infamous search function the other day when I posted about bearings...
I also made a set of main bearings for the D2 pony.
Rax200,
Good idea, but I imagine developing & building new crankshafts would be prohibitive cost-wise. It's sad, but the crank may be the Unobtanium part that seals the fate of the pony motors...
I know some of them were built back up to standard back in the day, but at least in the one I bought, that didn't work that great...the buildup metal was coming off in flakes & really raising heck with the bearing as well as the seal.
Maybe the flame-spray process has improved since then-might be an option to save some cranks, I don't know...there's other issues that crop up too, the flywheel taper & keyway on the one I have was showing signs of problems too. And as somebody said above, always the possibility of a crack.
Sat, Mar 5, 2016 10:40 PM
