D2 5U oil cooler bypass
Thermodyne707
Send a private message to Thermodyne707
When bypassing the oil cooler ,what plug/caps size and style do I need and where is the check valve in the filter housing I need to remove?
Sat, Jan 30, 2016 7:51 AM
TOGNOT
i cant answer your question, but on a D2 I own, the previous owner just looped a hose from the cooler out put on the filter base to the cooler return on the base. Kind of like bypassing you heater core when it leaks
Sat, Jan 30, 2016 1:49 PM
ag-mike
Reply to TOGNOT:
u can try a bypass search, guud luck, it never wurks 4 me
Sat, Jan 30, 2016 8:57 PM
Reply to TOGNOT:
This is an annual subject, the last time about a year ago most of the answers were provided with previous links back to posts/threads with diagrams and photo's of where that check valve is.
IF I REMEMBER CORRECTLY AND IT IS EARLY IN THE MORNING FOR ME to say this, BUT it is under a plug going up the center of the oil filter housing more or less inline with those two ports.
OM will probably chime in soon and correct me but I also seem to remember he had the Part Number for the proper Caps to go in those hole as they are not standard Pipe thread.
Sat, Jan 30, 2016 8:59 PM
Reply to drujinin:
Use hydraulic fitting "O-ring Face Seal" plugs size dash10 (1"-14tpi) straight thread.
Remove face seal o-ring.
I also stretched a #116 Viton o-ring over the plug but I'm not sure that is necessary. I used Teflon paste pipe thread sealer.
Plugs are only a couple of $ each.
Plug the oil cooler too for a clean installation.
Remove oil cooler by-pass valve and spring.
Sun, Jan 31, 2016 12:32 AM
