D2-5U Lube requirements
igloo
Send a private message to igloo
I am searching for info on lube points and specifications for my D2.
I had a steer clutch and brake freeze up a few weeks back when it got cold so I figured it was time to drain and replace, but I don't know what to put back in or where to put it in.😕
Sun, Dec 24, 2006 1:23 AM
Steve A
Igloo
Regarding your request for D2 Lube points, there are many.The D2 Operation and mantnance instruction book list Lubrication instructions on page 6 all the way through page 21. It is a handy book with more than just basic owners manual info. They are listed for sale here and on E bay from time to time, also available from Cat legendary literature for big $
Regarding your frozen steering clutch, you are right its is time to Drain. But do not replace they should be dry clutches. There is a 3/4 inch pipe plug, one under each steering clutch you should remove to drain water and whatever. Some guys drill a small hole in the drain plug and put in a cotterpin to rattle around to keep it open.The Cat manual mentions washing the stearing clutch compartment with kerosene.
I believe someone here has the D2 manual posted on there website
Sun, Dec 24, 2006 3:12 AM
Steve A
Reply to Steve A:
Igloo
D2 Specifications U series
Sun, Dec 24, 2006 3:22 AM
igloo
Reply to Steve A:
Thanks Steve, I will look for the drain plugs tomorrow, I have a lot of tops to drag out of the woods when the ground freezes and it takes a lot longer when you can only turn to the right.
Sun, Dec 24, 2006 9:49 AM
