D2 5U Goes into gear, clutch won’t engage
Showing 1 to 10 of 15 results
rlitt
Send a private message to rlitt
Machine has been running fine. I parked it on the trailer and it set for a few weeks. The next time I started it to try and move, it goes into gear OK but soon as I put the clutch in, I can hear it catching but it will just barely start to move the tractor and then disengage.
Thu, Sep 13, 2018 6:42 AM
wimmera farmer
Thank you received: 10
Not in gear properly or gear selector lock problem. Try all gears?
Thu, Sep 13, 2018 6:53 AM
gemdozer
Thank you received: 25
The interlock mechanism is in probleme
Thu, Sep 13, 2018 6:56 AM
rlitt
Reply to gemdozer:
Tried all gears, same problem. It’s like it wants to slide into gear OK but just won’t stay
Thu, Sep 13, 2018 7:11 AM
rlitt
Reply to rlitt:
What is an interlock mechanism and is it adjustable?
Thu, Sep 13, 2018 7:13 AM
Chuck C
Reply to rlitt:
Open the cover over the clutch and see if all the links in the over center mechanism are all hooked up. This happened to me. The cotter pin came out of the pin retaining the links. The clutch disk became crooked and tore all the teeth off the disk. Look in there and see if you can see any broken teeth in the bottom of the clutch compartment.
Chuck C
Thu, Sep 13, 2018 7:51 AM
rlitt
Reply to Chuck C:
Chuck C
Yes, there are some broken teeth. I will check for the loose over center left mechanism next. When I reach inside to feel the linkage, there does seem to be more play on some than others. I’ll check that next. Thank you
Thu, Sep 13, 2018 8:07 AM
I am confused .........does the shifter stay in gear when you engage the clutch and the clutch pop out again
Or does the clutch stay engaged and the shifter pop out?
Or do both stay in place and the tractor fails to move?
While the tractor is sitting there instead of moving, what happens if you pull on the clutch? What about the shifter?
Thu, Sep 13, 2018 9:06 PM
rlitt
Stays in gear, clutch pops out. Clutch will engage well tractor is sitting still.
Thu, Sep 13, 2018 11:18 PM
Can you pull the clutch back hard and get the tractor to do anything?
Do you have to snap the clutch in (back) and out (forward) or does it just mush back and forth without snapping?
If its snapping in and out, your clutch disk teeth are stripped off the outside edge. New clutch disks for the 4u/5u tractors are available aftermarket from general gear. I don't know the current availability of the thinner disks for the J series. The later u series have the clutch that can be removed from the top without pulling the engine.
Thu, Sep 13, 2018 11:31 PM
rlitt
OK, thanks for all the replies. Based on those replies and what I’m seeing inside, it looks like there are teeth that have come off the clutch disk. My next question is am I looking for a drive plate or a pressure plate. In my service manual it shows teeth on the drive plate. What I can’t tell, is, are there teeth on the pressure plates that engage that drive plate as well? Getting ready to start searching parts. Thanks
Fri, Sep 14, 2018 3:22 AM
