d2 5u generator question
m249bb
Send a private message to m249bb
Hello,
I have a newly aquired d2 5u6625 that has had the generator removed by it prior owner. I want to replace it. I looked in the parts book but was unable to determine the correct generator for it. I have found both bosch and delco built generators for the d2 models, however the book is calling out either a 20 tooth or 14 tooth gear for the shaft. Does anyone know what would be the correct generator / gear for that era cat d2. Neither the dealer nor the parts manual were definative on what my cat should actually have. Any help is greatly appreciated.
thanks
charlie
Fri, Sep 27, 2013 1:35 AM
Thank you received: 39
If you look in the parts book under attachments you will find that under the starting group number it will describe what generator is a match.
Fri, Sep 27, 2013 2:59 AM
