D2 5U Front PTO Questions
rlitt
Send a private message to rlitt
Hello,
Moving on to the next project on my D2. Last project was replacing the clutch disk between the pressure plates. Because this 5U is the earlier version, I had to remove the diesel motor which required taking off the front hydraulic pump (model 44). Upon removal, I noticed the PTO shaft was very wobbly. I’m having trouble researching diagrams and potential needed repair parts. Any direction is appreciated.
Wed, Oct 10, 2018 9:56 AM
restore49
Is the play in the Yoke or splines - the u joint is standard parts store item. Bob
Wed, Oct 10, 2018 7:15 PM
Reply to restore49:
What's the #44 s/n?
They use a gear type coupling the would normally be floppy without the shaft support of the mounted hydraulic unit.
Wed, Oct 10, 2018 10:54 PM
rlitt
What's the #44 s/n?
Serial # is 9W493
Thu, Oct 11, 2018 7:17 AM
Reply to rlitt:
Serial # is 9W493
Mounting group details....
Thu, Oct 11, 2018 10:00 AM
